leaky mini
Posted 14 February 2006 - 09:26 PM
floor was soaked a nice pond in the driver side footwell!!
ne1 got any ideas where it cud be leaking from??
cheers fergie
Posted 14 February 2006 - 09:33 PM
or worst case scenario would be a hole in the floor.
try getting the carpets up and have a good look around for any signs.
is it the first time its done it aswell? if so could be nothing major as such, but check to see if it keeps reoccuring.
Posted 14 February 2006 - 09:35 PM
Posted 14 February 2006 - 09:42 PM
I havent seen a mini yet that doent leak , just drill a hole in the floor to let the water out faster
lol true!
well when i bought it back in november it was full of water this is the first time its been out in the rain in a while
i've got the carpet out and well i dont think its a hole in the floor because the water got in during the night.
the door looks alrite ill have another look tomorrow.
cheers fergie
Posted 14 February 2006 - 10:10 PM
use a hose pipe and get someone to sit in the mini while you squirt water over it
Posted 14 February 2006 - 10:12 PM
door or window rubbers
...from a hose pipe!!
Posted 14 February 2006 - 10:46 PM
Posted 14 February 2006 - 11:04 PM
cheers Fergie
Posted 15 February 2006 - 06:50 PM
Look at the pedal box that leaks on mine, and check all the gromits on the bulkhead are there, mine is missing one and has a nice line of surface rust from it , also look at the back of your wheel arch, up inside, on one of mine i had a tiny hole there and it came in by the bucket load there...
btu as people have said, look at window and door seals, thats the obvious one
Posted 15 February 2006 - 07:04 PM
Mine don't leak
Although i have got new door and window rubbers all round
Posted 15 February 2006 - 09:28 PM
My mini didn't have hardly any plastic sheet behind the door card left, but when we covered the holes, the car stopped leaking!
Posted 15 February 2006 - 09:45 PM
So you have the ONE thenI havent seen a mini yet that doent leak , just drill a hole in the floor to let the water out faster
Mine don't leak
The above comment was meant a bit tounge in cheek
It is almost true
One mini i had let in so much water i gave up , removed all the carpets and drilled drain holes (the carpets just soaked up the water like a sponge so the mini never dried out)
Posted 15 February 2006 - 10:00 PM
well yes,
But only when I don't leave the window open a tad when I washed it once
Posted 15 February 2006 - 11:06 PM
Fergie
