Ignition Coil Burning Out
Posted 18 January 2012 - 04:00 PM
It has a ballasted ignition system but when running I still have 12volts on the + on the coil and from my understanding this will burn a 9volt coil out in next to no time.
So my question is can I just run a new feed from te fuse box to a 12volt coil and not ruin my electronic distributor?
Posted 18 January 2012 - 04:09 PM
If you short the CB (negative) side of the coil to earth on the engine block, engine not running, you should see about 6 to 8V only on the positive coil terminal, thus proving that the ballast resistor is working. If you still see 12V there is a wiring fault.
I think the ballast resistor is not in circuit, or is being bypassed. Is the connection to the starter solenoid, which provides a bypass for starting, on the correct terminal?
Posted 18 January 2012 - 04:21 PM
I'm not sure, the yellow/white wire is currently on the bottom solenoid output as you look at the starter through the grill, is that correct?
Posted 18 January 2012 - 05:42 PM
Posted 18 January 2012 - 06:22 PM
I also train earthing the - on the coil to the block with the ignition on and the voltage dropped to 4.5v! Seems a little low to me?
Posted 18 January 2012 - 07:49 PM
When you measured the 4.5V with the coil (-) earthed and engine not running... where did you measure between? Were you measuring from coil (+) to earth or from coil (+) to coil (-)?
Posted 18 January 2012 - 07:55 PM
Posted 18 January 2012 - 08:33 PM
If you are using the Lucas system that is. The aftermarket electronic systems don't do this, and different models have different requirements regarding ballasting.
Posted 18 January 2012 - 09:15 PM
The current system is a ballasted system.
So if I was to put a 12v supply to a 12v coil could that fix the issue if I have a Lucas dizzy?
Sorry for all the questions but I had to read your reply about 10 times Dan but thank you very much!
Posted 18 January 2012 - 09:28 PM
If it's any other system then get a picture or the make and model and come back to tell us what it is.
Posted 18 January 2012 - 09:45 PM
http://www.minispeed...tributor-vacuum
http://www.minispeed...eapi_node/11410
Was that 8 or 0.8 ohms?
Is it not possible to run a standard 12v coil with a electronic dizzy then? Just wondering as the last distributor that was fitted was the cause of the problems.
Posted 18 January 2012 - 10:51 PM
Sorry I meant about 0.8 ohms, now corrected above.
Posted 18 January 2012 - 11:28 PM
It says about it having a yellow vac, does this mean maybe that the advance works slightly differently for a higher lift cam? I'm running a 286.
Posted 19 January 2012 - 04:54 PM
http://www.theminifo...__fromsearch__1
It still does the same thing, I crank it and it turns but struggles (not a flat battery I've checked all of that over and the battery is a month old). Could it possibly be something to do with the timing? It is making a similar sound to when an engine is trying to fire to close to TDC
Posted 19 January 2012 - 06:11 PM
