Ignition Coil Burning Out
16 replies to this topic
#16 dwealds
dwealds
  • 199 posts
  • Local Club: WSMOC, LSMOC
Posted 19 January 2012 - 06:43 PM
Nope. Minispeed said the dizzy drive was 180 degrees out in the engine so once they'd fitted the new dizzy they switched the leads 180 degrees from what they're supposed to be, this fixed it and it started and ran beautifully. I has just got progressively worse from collecting it from them and now wont start at all.
What I don't understand is that when i disconnect the coil the engine turns over like you'd expect it to but when i connect the coil it struggles to turn over, sounds like a flat battery I know but it's not. I also checked the coil resistance and it's 0.9 ohms
#17 WiredbyWilson
WiredbyWilson
    WiredByWilson
  • 5,004 posts
  • Local Club: WiredByWilson
Posted 25 January 2012 - 12:15 PM
Have you tried running a new earth, my high compression 1330 used to do somethign similar then jam the starter. Put a bigger earth from battery to body and direct from starter casing to body and sorted the problem out.
