Doe anyone know the correct length of the alternator belt for an 84
As the old one I have seams too short, seamed fine before
Even with the tensioner bolts loosened, even removed some of them completely it still didn’t want to go on
When I finally got in on and tried tensioning it there’s just no extra in the belt
Ended up bending my pry bar and a nice long gash down me leg from the front valance
Looks like I’m stuck on hear with my feet up till it stops bleeding
I will try Halfords tomorrow but doubt they will know
The car is an 84 with standard crank and water pump pulleys and an A127 alternator
Thanks,
Alternator belt length
1984mini25
, Feb 16 2006 04:08 PM
3 replies to this topic
Posted 16 February 2006 - 04:08 PM
Posted 16 February 2006 - 04:44 PM
Take you old belt down to halfords or motor factors and just get a slightly longer one !!!!
Posted 16 February 2006 - 07:01 PM
did u undo all the tensioner bolts, theres one at the back end of the 'banana' type bit that needs loosening to allow you to move the alternator back and forward properly...
Dave
Dave
Posted 16 February 2006 - 07:14 PM
Yep loosened all the bolts
But when I did finally get the belt on (Had to take the alternator off to get the belt on) and tried to tension it
The end of that 'banana' type bit was still resting up against one of the water pump bolts
Which to me seams a bit wrong compared to ones I have seen
