Don’t know if anyone else has had this but ere goes
When I removed one of the heater hoses from the bottom hose
As I undid the jubilee clips and pulled the two hoses apart
The peace of metal tubing inside was so badly corroded it just fell apart
Only now I have got to the point of putting everything back
But can no longer reconnect these two hoses
Have tried to look for coolant hose joiners but haven’t been able in finding any small enough
Would I have any probs with using ½” copper pipe normally used for central heating systems?
As I have some spare and probably won’t corrode as badly as what was used before
And before I forget, where I can I get hold of some large metal p-clips?
So I can keep my new Speedo and breather hose off the exhaust manifold
And attach them to the rocker cover bolts, rather that trying with cable ties (which might look messy) out of the way of the exhaust and moving parts
Any suggestions would me much appreciated
Coolant hose joiners
1984mini25
, Feb 16 2006 09:15 PM
2 replies to this topic
Posted 16 February 2006 - 09:15 PM
Posted 16 February 2006 - 09:20 PM
RallyDesign do good stuff, and they are usually cheaper than Demon tweeks.
Posted 16 February 2006 - 11:16 PM
I am guessing you have 1/2" pipes and not the later 5/8" if so copper pipe ok.
if you have 5/8" pipes you can get 16mm steel pipe tube from B+Q in a 1m length for a few quid and cut to length, you can maybe get 1/2" too but I havent looked.
the Mocal website www.thinkauto.com has hose joiners and so does www.vehicle-wiring-products.co.uk
Also maybe try the racks of yellow packs of little car screws and crimp connectors in your local car spaes shop, they have 12mm white plastic hose joiners amongst them over here.
