1100Cc Engine Build
Posted 04 February 2012 - 11:49 PM
THE HEAD
I haven't decided what to do yet either get the 202 head modified or save up an buy a modified head form a good dealer as not sure on cost to get standard head mofified vs part exchange
But will be using 1:3:1 roller rockers
ENGINE
I'm going to compleatly strip down the engine
Clean it all up
Will put all new gaskets bearings ect in
Along with a Kent 286 cam kit
New oil and water pump
All new timing gear (the one with the double chain can't remember the actual name )
GEAR BOX
I think I will leave the gear box and diff as standard as can't afford a straight cut or LSD
And not really Nesserary for a road car
I will be using a hif38 with itg ram air kit
Im getting a custom exhaust made once engine is fitted but will attach to a LCB
Posted 04 February 2012 - 11:58 PM
Posted 05 February 2012 - 12:11 AM
I thought of the 286 or 276 as in the yellow bible it says a cam with as much as 280* produces quiet acceptable results even down the low end of the rev range
Posted 05 February 2012 - 12:27 AM
Posted 05 February 2012 - 12:32 AM
Will th car still peform well if I leave the head standard
Posted 05 February 2012 - 12:53 AM
Posted 05 February 2012 - 12:56 AM
Posted 05 February 2012 - 01:04 AM
I've seen it been done and I think I could do it with my dremel just not confident to do it
read philip g cadwells thread on the 1275 eating 998, i'm sure that there are good pics of the block that he pocketed, just dont go too far down the bore and use the head gasket as reference, you dont have to pocket down much anyway .
Posted 05 February 2012 - 09:15 AM
All I have to do is pocket the block
And what alternatives are there if I don't pocket the block what other head could I use
Posted 05 February 2012 - 09:27 AM
If the Kent 276 is the absolute max for a 1098 I'm asuming a 266 or a mg metro can would be a better choice
In just thinking that to keep cost down I could use the mg metro cam I'm just in sure on results
Posted 05 February 2012 - 09:42 AM
Any idea how deep to go
And what about CR
Posted 05 February 2012 - 09:51 AM
So if I use a 1275 head on my 1100 will it need skimming
the 1275 head wont need skimming to fit the 1098 engine, the only other alternative is the 12G 295 cooper head, these do need a lot skimmed from them to fit the 1098 engine and they are expensive to buy secondhand (over £100 in most cases) the MG metro cam works well in the small bore engines and the same goes for the 266.
Posted 05 February 2012 - 10:08 AM
So specs could be
1098
12g940
266/276 cam
Hif38
Posted 05 February 2012 - 10:11 AM
Ok so i just need to pocket the block
So specs could be
1098
12g940
266/276 cam
Hif38
yes, also check the crank/shell bearings for wear, also the pistons and bores as these engines are notorious for burning oil, and you may as well fit a new oil pump while its in bits.
Posted 05 February 2012 - 10:19 AM
New water and oil pump
