1100Cc Engine Build
36 replies to this topic
#16 Rusty1182
Rusty1182
  • 389 posts
  • Local Club: Mini Allsorts
Posted 05 February 2012 - 02:36 PM
My initial idea was to build a nippy 998 but I have been offered a 1100 engine an gearbox so that has now become my engine project
THE HEAD
will be using a 1275 head with double valve springs and possibly 1:3:1 roller rockers
ENGINE
complete rebuild using standard crank pistons and con rod
will use a sw5-07 cam kit
GEAR BOX
I think I will leave the gear box and diff as standard as can't afford a straight cut or LSD
And not really Nesserary for a road car
I will be using a hif38 with itg ram air kit
Im getting a custom exhaust made once engine is fitted but will attach to a LCB
#17 Rusty1182
Rusty1182
  • 389 posts
Posted 05 February 2012 - 11:22 PM
im picking the engine up hopfully end of month then will start work and will add lost of piccys
im doing this on a budget and mainly using used items
if i could afford it i would have a high spec engine built for me but thats not going to happen
this will be my first engine build so not a bad start i suppose
once done i may turn my 998 into something special
#18 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 06 February 2012 - 05:48 PM
I am not here to flame or anything but i think it is fair that i point a few things out to you.
Because the 1098 is a stroked version of the 998 engine the characteristics are different. This engine is designed to make torque not bhp.
If you hold an 1100 for a period at above 6000rpm, The cranks snap. And often take other bits with it.
You do not want to put a 286 into an 1100 this is completely wrong for this bore/ stroke combination. A 266 is ideal for this engine as it exacerbates the toque produced from a longer stroke. The sw5 is similar to the 266.
If you want it to rev (a 286) and produce bhp then you need a heavily modified 998 or 1275.
I wrote a guide on the small bore engine, over 50 pages of information from stage ones to turbos. If you are interested drop me a PM.
Jesus
Edited by twrminisport, 06 February 2012 - 05:48 PM.
#19 Rusty1182
Rusty1182
  • 389 posts
Posted 06 February 2012 - 06:37 PM
yh ive been doing some research and decided to now use a MG metro cam
#20 welshraider
welshraider
  • 61 posts
Posted 06 February 2012 - 06:46 PM
can you get any heavy duty crank shafts for the 1098 engines or is there not such a thing
#21 Rusty1182
Rusty1182
  • 389 posts
Posted 06 February 2012 - 09:07 PM
1098
940 head
MG cam
Would I need to sink the exhaust valves by 40 thou
#22 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 06 February 2012 - 09:11 PM
what happened to the 202 head? You cahnge your mind more than me!
#23 Rusty1182
Rusty1182
  • 389 posts
Posted 06 February 2012 - 09:13 PM
Yh I was going to do a 998 with 202 head
Now I'm doing a 1098 with 940 head MG cam
only because I was offered a 1098 for £80
I will be selling two 202 heads soon
#24 Rusty1182
Rusty1182
  • 389 posts
Posted 06 February 2012 - 09:14 PM
Just need to decide wether to pocket block or sink valves
#25 Rusty1182
Rusty1182
  • 389 posts
Posted 07 February 2012 - 12:11 AM
Apparently when useing a 1275 head gasket on a 998 u need to block off some water ways
Or would it be best to fit a dry deck kit
#26 twrminisport
twrminisport
    Jesus
  • 913 posts
Posted 07 February 2012 - 10:09 AM
If you are sending the head in to have some work done on it anyway then i would sink the exhaust valves but you will need to measure first. 40 thou is normally enough but check first because you don't want those valves hitting the block :)
Otherwise get the block pocketed for about 40 quid or DIY it.
No heavy duty cranks as far as i know that alleviate the problems above.
Jesus
#27 Rusty1182
Rusty1182
  • 389 posts
Posted 07 February 2012 - 11:30 AM
I wasent going to do any work to the head apart from sinking the valvesv
#28 Rusty1182
Rusty1182
  • 389 posts
Posted 07 February 2012 - 08:00 PM
£40 I wish
Phoned up my local engineering place and thay want £130+vat
#29 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 08 February 2012 - 03:00 PM
£130 is robbery, I think MRA minis do it for £50 from memory
#30 Rusty1182
Rusty1182
  • 389 posts
Posted 09 February 2012 - 10:54 AM
Well I'm picking up the engine this weekend
I will be striping it down and taking it up to MRA mini to pocket the block
Will add photos soon
