Question About The Water Temp. Transducer; Mpi
26 replies to this topic
#16 RawlinsGTR
RawlinsGTR
    Formally known as Dog
  • 1,046 posts
Posted 10 February 2012 - 01:32 PM
Cool, thanks. Better get draining some fluid then!!
#17 bcjames
bcjames
  • 2,741 posts
Posted 10 February 2012 - 01:44 PM
You don't need to drain anything just to test the fan.
#18 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 10 February 2012 - 01:53 PM
Yeah but removing the temp sensor means that some fluid will come out; surely?
EDIT: I'm being stupid, aren't I. You can just unplug the sensor :P
Edited by Dog., 10 February 2012 - 01:54 PM.
#19 bcjames
bcjames
  • 2,741 posts
Posted 10 February 2012 - 01:54 PM
You don't remove the sensor, just disconnect it. Leave the bit with the spanner flats in place, and unplug the brown connector from it. No water, just wires!
#20 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 10 February 2012 - 01:58 PM
COOOOOL! Cheers James.
#21 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 10 February 2012 - 02:28 PM
Okay, just done that;
The fan doesn't turn on. Tried it with just ignition on, also tried it with the engine actually on.
So what does that mean? Have I still various things to check?
#22 bcjames
bcjames
  • 2,741 posts
Posted 10 February 2012 - 02:54 PM
Can you put some power directly to the fan? Just to check it works independently.
#23 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 10 February 2012 - 03:00 PM
Not sure how I can do that. D'you know of any way? I mean, I can find 12V but I don't know whether the relay steps down the power to the actual fan..
#24 bcjames
bcjames
  • 2,741 posts
Posted 10 February 2012 - 03:04 PM
As far as I know it is 12v. I think there are just two wires to the fan, so you could unplug it, then use some wire to attach a battery to the two contacts in the plug.
The fan also has a relay, but I'm not sure where that is. I'll have a look in the Haynes, to see if that reveals anything.
#25 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 10 February 2012 - 03:10 PM
Yeah, okay. Cool, cheers. :)
#26 Bartje
Bartje
  • 58 posts
  • Local Club: Mini Club Zuid Holland
Posted 19 March 2012 - 04:39 PM
Simon: I hope to be in the UK this weekend for Brooklands, I can bring my code reader to see if there's a fault in the ECU and to test the fan activating from the ECU.
#27 RawlinsGTR
RawlinsGTR
  • 1,046 posts
Posted 19 March 2012 - 05:03 PM
Hi..
No need to now, I got it sorted a while ago.. just forgot to say on here.
But.. it would be nice to see what fault codes I've got showing up, so if you don't mind, I fancy a meet up and test. :D
