Need Help With Weber Dcoe 40! Wont Idle On Cyl 1 And 4
22 replies to this topic
#16 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 07 February 2012 - 09:16 PM
'tis higher on the inner two.....coincidence?
Hard to tell until it's run in. I would definitely try a little more advance and higher idle speed, but like I said, I'm no engine tuner.
#17 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 07 February 2012 - 09:36 PM
thanks for the help! Hope i come right :(
#18 sledgehammer
sledgehammer
  • 3,129 posts
Posted 07 February 2012 - 10:10 PM
Hopefully something nice and simple
#19 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 08 February 2012 - 06:00 AM
could it be my weber box is too small? There is about an inch of clearance all around and two inches behind
#20 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 08 February 2012 - 08:47 AM
Nah, I doubt it's too small. When you think about it really, it only needs to have enough clearance around the carb to ensure that the airflow into the box is greater than the airflow into the carb......I guess.
#21 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 08 February 2012 - 10:37 AM
could my idle jets be too big or too small? it seems to smoke lots too. is this due to the engine still needing to be run in? it smells like fuel and oil... stem seals are new. whole head has been re-done too... it must be carb. it isnt firing on 1 and 4 much at all!
#22 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 08 February 2012 - 01:26 PM
where abouts are you/the car?
Is there anyone you know that could pop along and have a look?
It's possibly carb setup, but not definitely. Your compression test, I assume you did them with all four plugs out? What position was the throttle in when you did them?
#23 bwi_bwi_12
bwi_bwi_12
  • 43 posts
  • Local Club: n/a
Posted 08 February 2012 - 09:27 PM
Im in Cape Town! still need to set the carb up properly.
compression test was done with all the plugs out, yes. and the throttle was fully closed with no choke either. What difference does this make during the test?
