"tamer" = more fun at lower revs with bags of torque...
its a short duration high lift cam: excellent for the road where revs are 'low'.
bags of torque, good with emissions.
runs out of grunt from 6rpm... but seriously if you run a road car at 'high' revs all the time then how long do you think its gonna last?
Thanks thats a good reply. I presume you use the SW5 yourself then? if so what size is your engine? and what are your power figures? if you know them.
I rarely rev over 6K as in the current engine it would be pointless anyway so I am happy to have more torque.
I will probably go with the SW5 then
Have built a few engines with this cam - 1293 through to 1380's - carbs and SPi
Its not a high, peaky HP type of cam... it will though give you a load of torque right where you need it when driving around town and on motorways. smooth idle with no 'lumpyness'. good on fuel and generally spot on.
because the torque is spread across the range, you can (and i have) built it ontop of the wide ratio gearbox sets and you do get the best of both worlds when coupled up with a 3.1 diff: excellent acceleration from low revs through to excellent cruising on the motorway.
if, however: you are building a track monster or interested in just HP then its not the cam to use.
Because you can drive it 'sensibly' you can use standard valve springs (so no more wear occuring due to heavy springs), and you're not revving the nuts out of it = last longer...
