Arden 8 Port
20 replies to this topic
#1 JmayfairJ
JmayfairJ
  • 234 posts
Posted 13 February 2012 - 09:13 PM
i think its an arden head anyway
basically ive had a pipeline dream of putting a turbo on my 998 mini for a while now but been told by a friend today that "you dont want to turbo it, what you want is an 8 port"
"yes but arnt they expensive?"
"not if you know someone who has one" :D
so if i get offered an 8 port in the near future what should i do if its for reasonable money? i quite like the idea of it over turboing
#2 george91
george91
  • 883 posts
Posted 13 February 2012 - 09:20 PM
its still going to be more expensive than going turbo, the Arden heads are always expensive be it a new cast or an old one. It all depends on your budget anyway, but as an easier and cheaper option have a look at 7 port heads, they have the main benefit of 8 ports as each cylinder gets its own inlet port, but without the difficulty of building an 8 port which needs more modifications. Depending on how much power you want a turbo could be a better option.
#3 JmayfairJ
JmayfairJ
  • 234 posts
Posted 13 February 2012 - 09:29 PM
well at the moment im assuming the head is complete with work done to it where as if i was to turbo it i would be doing as much as i can myself in terms of fabricating
#4 mini13
mini13
  • 3,811 posts
Posted 13 February 2012 - 09:38 PM
remember with the arden that you'll need a special cam,
you unlikly to get an arden head S/H for much under a grand, on top of that you'll need the exh, inlets, carbs, Head studs, pushrods, plus you'll need to pocket the block it all adds up....
#5 george91
george91
  • 883 posts
Posted 13 February 2012 - 09:39 PM
Well they need a specific cam and push rods for starters, also different rockers, and of course a specific exhaust manifold. You will want someone to build the engine for you really too. As for turbo there isn't necessarily any fabrication work required, it depends what manifold, down pipe and inlet pipes you use.
#6 mini13
mini13
  • 3,811 posts
Posted 13 February 2012 - 09:40 PM
also when somone says "you want to...." it actually means "I want to but cant afford too or dont know how to..." which means you probably cant either!
#7 JmayfairJ
JmayfairJ
  • 234 posts
Posted 13 February 2012 - 09:44 PM
yeah i see what you mean about the 8 port all adding up, id have to see what i get offered first with the 8 port, as for the turbo i already have the carb and i would be making my own exhaust system including manifolds, would just have to source smaller turbo so i dont have to modify the bulkhead, but at the moment the car is awaiting paint anyway thats why i thought wich ever i go with i could source the parts over a fair bit of time
i just like the idea of an 8 port though its something different
#8 JmayfairJ
JmayfairJ
  • 234 posts
Posted 13 February 2012 - 09:45 PM
theres plenty of over time on at work :D
#9 JmayfairJ
JmayfairJ
  • 234 posts
Posted 13 February 2012 - 09:46 PM
plus i work for a welding and fabrication company so i have access to welders/ waterjet and basic machine shop or could always send stuff off to my local machine shop
#10 mk1leg
mk1leg
  • 9,343 posts
Posted 13 February 2012 - 09:55 PM
I would love to put an 8 port on my 1380......but this will have too wait a few years................... :proud: :D
#11 Sam Walters
Sam Walters
  • 2,765 posts
Posted 13 February 2012 - 10:23 PM
10-15k`s worth?
#12 JmayfairJ
JmayfairJ
  • 234 posts
Posted 13 February 2012 - 10:40 PM
10-15k`s worth?
where did you get that figure from?
#13 MJWarren
MJWarren
  • 705 posts
  • Local Club: DCMOC
Posted 13 February 2012 - 10:42 PM
10-15k`s worth?
Won't cost 15k to build a 8 port.
Edited by MJWarren, 13 February 2012 - 10:43 PM.
#14 george91
george91
  • 883 posts
Posted 13 February 2012 - 11:03 PM
Yeah 10k+ if you want a full race engine, but for a spec that is road usable i would think 5-8k all built is a better estimate.
#15 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 14 February 2012 - 12:38 AM
I'm probably completely wrong about this but I didn't think you could fit the 8 port to a 998. Don't the big ends hit the cam?
