Hi there, Just bought a gas flowed 12G295 head and i am fitting it to my stage 1 998cc. what carb should i use. A mate has given me twin 1.5's, are these the best for it. what are the advantages of twin 1.25's over twin 1.5's. any help is great. thanks
What carb?
01smartc
, Feb 19 2006 10:22 AM
6 replies to this topic
Posted 19 February 2006 - 10:22 AM
Posted 19 February 2006 - 10:33 AM
with a 998, twin 1.5 will be to big and more than likelly keep flooding the engine
you can use a HIF38 , a HS4 which you probablly have on it now , or go for twin 1.25
the HIF44 If i remember is more for larger engines..
Posted 19 February 2006 - 10:48 AM
A hif44 Will work well on a highly tuned 998, but will be too much for a mild though. depending on the cam and what work your head has had would decide it.
try it on the origonal carb first.
Posted 20 February 2006 - 09:14 AM
??? anyone else
Posted 20 February 2006 - 04:01 PM
As Cowboy says, an HIF38, HS4 or twin HS2's really for a 998. I use twin HS2's myself but I am considering going to a single HIF38. The HIF38 is the most modern carb of the three and probably the most fuel efficient for the same performance. The small twins should be a bit more responsive than a larger single would lower down the range, and the single HS4 would be the budget choice as it's probably what you already have and perfectly serviceable.
Posted 20 February 2006 - 04:11 PM
You could download winSU and try having a look with an HIF38, and with an HIF44, and see what needles it recommends and what power curves it predicts?
Dave
Dave
Posted 20 February 2006 - 07:15 PM
Twin Webers all the way
nah just kiddin
nah just kiddin
