Hi I seem to have a problem where where the revs do not go down. This is most noticeable when I come to a stop and put the clutch down, and the revs seem to increase to 3000 rpm. It idles no lower than 1500 or so when it used to be 1000. I will now read through mini sprockets post(s) about spi system to find a solution. Bearing in mind this was first major run today under load after having a cam change
Throttle Problems
m3ntalist
, Feb 19 2006 02:56 PM
3 replies to this topic
Posted 19 February 2006 - 02:56 PM
Posted 19 February 2006 - 03:55 PM
i take it you've allready checked that the release springs are working properlly, also check the chock cable isnt sticking.
look at the simple things first, before you have to start looking at your timing of the new cam and the ignition timing.
there could also be a possabilaty that the managemant system is saying it needs more fue so is doing it.
just a few things to have a look at
Posted 19 February 2006 - 05:05 PM
No choke on an spi.
Check that the cable is not kinked or trapped anywhere. and has the throttle cable been indexed.
Check back at the topic I am doing later as I am currently on the write up for this peritular subject
Posted 19 February 2006 - 08:20 PM
No choke on an spi.
Ok will do when I get in tomorrow night, my eyes hurt, been staring at this screen for hours, feels like ive been at work! It probably is something simple, other that that it was fine! Good power. WIll have to take the cat off though, im sure it sounds worse with it on (was on for MOT )
