On a 1994 cooper monte carlo is there another fuse box inside the car?
Alex
Fuse boxes...
AlexF2003
, Feb 19 2006 03:02 PM
3 replies to this topic
Posted 19 February 2006 - 03:02 PM
Posted 19 February 2006 - 05:20 PM
don't think so but there is inline fuses behind the speedo block
Posted 20 February 2006 - 04:06 PM
If your car has the large blade fuse block (24 fuses or something like that) on the bulkhead ahead of the driver (rhd) then that's it for fuses. If you have the small 4 way glass cartridge fuse box in that position then you will also have a bundle of in-line fuses above the air filter, tucked up under the scuttle panel. I don't know of any being fitted behind the clocks though.....
Posted 20 February 2006 - 05:32 PM
i have ones that are hidden behind the speed on a 92 k mayfair.
they are for the the headlight flasher and a some other things that i can't remember.
will check in the haynes and get back to you.
