I've fitted it all up and wired in in but just refuses to work. If used a combination of different earth (-) and positives (+) but none seem to work. If checked the distance from the unit and the disc and all seems fine. The only things I can think of at the moment is that the unit does not work or I am missing out something very obvious, probably the latter.
The only difference to the instructions to the wiring I have done is that I have connected my positive (+) to fuse 1 on the fuse box (ignition stage II) as my coil does not provide a 12v output (it's a 1987). Also the earth is not connected to the negative (-) of the coil, it is connected to the bodywork. I have ensured that this is bare, clean metal and also tried using the main engine earth strap.
Would be grateful if someone could help asap as the mini is dead. Everything worked fine before these were changed.
Cheers, Jam2005
