The only wire that has been near the coil is the black one off the module. I don't get why it worked and then all of a sudden stopped. The rev gauge seemed to bounce a little a few seconds before the engine cut out.
Electronic Ignition Problems
jam2005
, Feb 19 2006 07:35 PM
21 replies to this topic
#16
Posted 20 February 2006 - 10:53 PM
#17
Posted 21 February 2006 - 01:20 PM
Take Dan's advice and refit the points dizzy (correctly adjusted). If that works, the problem is in the Lumenition unit or how you wired it.
If you want troubleshooting help with various aspects of the ignition system, download the PDF I posted a link to earlier.
#18
Posted 21 February 2006 - 03:46 PM
Thanks for the help. I will fit the old points and condenser back on tonight and post up again. Hopefully the car will be running and I won;t have messed up anything else.
#19
Posted 21 February 2006 - 06:18 PM
Got the car running on the original points and condensor so that means that the electronic igntion is nackered as I know ive got the wiring correct.
Cheers for the help people, you have all been great
Shame about the electronic igntion though. Can I use one off a 998cc metro?
#20
Posted 21 February 2006 - 09:26 PM
I can only speculate that you should be able to move the electronics from one distributor to another. (No Metros and very few A+ engines over here). A 998 Metro engine shouldn't have any different spark requirements than a 1275 so it should be a question of "does it fit" more than is it suitable... and it should fit.
#21
Posted 21 February 2006 - 09:38 PM
didnt metros have different advance curves though?
#22
Posted 21 February 2006 - 11:58 PM
I'm not sure
