Electrical Prob
Posted 21 February 2006 - 01:43 PM
Posted 21 February 2006 - 01:44 PM
Posted 21 February 2006 - 01:57 PM
Posted 21 February 2006 - 02:04 PM
Posted 21 February 2006 - 02:33 PM
also have you checked the battery voltage with the engine off (around 12v) and the engine on (around 14v) this indicates if the alternator is charging the battery or not.
Posted 21 February 2006 - 02:38 PM
do you get a red light on your dash with the ign on?
This is a crucial part of the charging system as it completes the circuit....
If it is fused you battery charging circuit is incomplete, have a look through the old posts here as this has came up many times
cheers
Posted 21 February 2006 - 04:24 PM
Posted 21 February 2006 - 05:45 PM
Is the charge light on when you switch on the ignition... BEFORE you start the engine? It needs to be.
As mentioned, the lamp has to be working to power the field coils of the alternator before it gets up to speed. If the lamp is disconnected or burned out, even an otherwise fully functioning alternator will fail to make any electricity.
Posted 21 February 2006 - 06:09 PM
Let's elaborate on the charge indicator light question.
And if it is, get a cheap multi meter and check the voltages over the battery yourself. If your battery voltage is low (should be 12V) then charge your battery over night with a car battery charger.
If the voltage is extremely low (less than 8V) you will need to buy a new battery, or your battery charger may have a re-conditioner function for flat batteries, this works for a while but ultimatly your battery will not hold its charge for very long and you will have to charge it every time your car is standing for a while.
If the battery is flat or only holds a few volts, check the electrolite levels (the water surrounding the plates inside). ensure the elctrolite is completely covering all the plates. If there is little or no electrolite in the battery, it is quite possible that your battery is shorting to earth somewhere (boiling off the electrolite). To check this, disconnect the positive lead on your battery, and with your multi meter set to the omega symbol, connect a multi meter lead to the positive battery lead and the other to the negative lead. If the reading is between 0 and 10 ohms you have a short to earth and thats what is discharging your battery. After the short is fixed you will need a new battery.
Posted 21 February 2006 - 06:31 PM
TTFN,
Dave
Posted 21 February 2006 - 07:43 PM
Posted 21 February 2006 - 08:00 PM
the battery is new and the alternator charges the battery.
does anyone know what reading the alternator should have when the engine is running???
Posted 21 February 2006 - 08:02 PM
Posted 22 February 2006 - 08:16 AM
then again could change it to find that its a fault in the loom.
Posted 22 February 2006 - 12:30 PM
