Hi everyone,
Could anyone tell me whether or not a pre 76 pedal box will bolt up to a post 76 shell?
Also, what are the different brake switch arrangements for the early and late pedal boxes?
Pedal Boxes
850mini
, Mar 03 2012 11:39 PM
1 reply to this topic
Posted 03 March 2012 - 11:39 PM
Posted 04 March 2012 - 12:00 AM
Yes and no,
It will fit but the inboard ends are different. Early ones are shorter with a couple of bolts,, later ones are "sandwiched" in the steering column bracket.
There is no switch on some early boxes (hydraulic one used instead), but you could easily drill a couple of holes & add one.
...... I suppose I should add the main difference is the pedal lever rates - the post 76 one has more,. which is why the brake pedal is raised to stop it running out of travel & hitting the floor - just something to be aware of.
