tow bars
19 replies to this topic
#1 mini-mad uk
mini-mad uk
  • 254 posts
  • Local Club: nmoc
Posted 22 February 2006 - 12:00 AM
hey ive been thinkin about gettin a tow bar fittin to my mini and i was wonderin wether itz a good idea an if so were can i get one from, an could i plz have some pics of the underneath of the minis with one on so i can see were they fit onto because i curious were they go.
many thanx
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 February 2006 - 09:46 AM
I have two styles of towbar, one fitted to the 72, which is about 30mm box section which connects to the rear of the subframe ( 4 bolts ) and then extends to connect to the floor pan through the rear seat squab panel.
I use that for a bike rack, and would easily tow a small trailer or 1/2 mini..
I have another on in the garage which is of slightly different design which is 2 angle bars instead of the box section, and again attaches to the subframe and rear squab, and also the rear valance...
If you're interested PM me, and I'll sort some photies out..
#3 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 22 February 2006 - 11:23 AM
Can you post the pics anyway GW, just out of interest, please?
#4 Tom Sanderson
Tom Sanderson
  • 708 posts
Posted 22 February 2006 - 11:27 AM
say a towbar on a mini that was bolted to two gussets welded in the middle of the back subframe
it looked verys strong
i have one of thoes ;D :ph34r:
#5 Grayedout
Grayedout
  • 901 posts
Posted 22 February 2006 - 11:50 AM
Also note that it is illegal to tow with a Mini built after a certain date as the powers that be decided the car wasn't fit for towing with and removed it's approval.
Will try and find the date !!!
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 February 2006 - 12:12 PM
Sometime in '98 I believe, so on the safety side.. pre 98 minis can have a towbar.
#7 Grayedout
Grayedout
  • 901 posts
Posted 22 February 2006 - 12:24 PM
Found it.
"All cars sold here from the 1st August 1998 must be European Whole Vehicle Type Approved. The vehicle maker decides when he applies for approval if the car will be allowed to tow and the car has towbar mounting points built in to the chassis."
#8 mini-mad uk
mini-mad uk
  • 254 posts
  • Local Club: nmoc
Posted 22 February 2006 - 04:49 PM
mines a 94 so does that mean i can or cant have one, soz bit thick, well i wonted to make a trailer for me an my m8z bikes (puch bikes) because itz kinda hard 2 fit couple of bikes in the back ;D , ermmmmm could u post the pics on here please because cant fink of anything to write in the pm box soz :ph34r: lol
thanx
#9 wolfie
wolfie
  • 1,149 posts
Posted 22 February 2006 - 07:43 PM
yes you can
dont forget the amount you can tow depends on the curb weight of the tow car, saying that i would not put alot on the towbar as it will stress the subframe mounts quite a bit if there the soft rubber type
try www.towequipe.co.uk search mini they have several mini towbars from saloons though to pickups
witter are prob the best known watling only make towbars for unusual towing vehicals i bought one from watling for my golf clipper convertible
#10 stevet4361
stevet4361
  • 78 posts
  • Local Club: n/a
Posted 18 January 2007 - 10:23 PM
Anyone know if these £45 towbars from towequipe are any good?, I'm thinking about putting one on my 85 mini Ritz.
#11 transtrack
transtrack
  • 29 posts
Posted 19 January 2007 - 12:07 AM
hi tow bars and minis dont mix in my opinion,the trailer would have to be lightweight thers not much you could carry and a 1985 mini dosnt have the braking ability,to cope with a trailer.But you are still going to do it anyway seriously we have fitted a tow bar to my sons mini I think it came off a Merc we cut it down welded plates to it and welded and bolted it to the subframe.It is now part of the car if we want to remove it it means a new rear subframe,and a lot of work with a angle grinder.It seamed a good idea at the time,dont they all,think twice about it is all I can suggest
#12 cornflakes5210
cornflakes5210
  • 258 posts
  • Local Club: sws south wales scoobys
Posted 19 January 2007 - 12:18 AM
Also remember that if you fit a towbar the value of your vehicle will go down aswell as it would be classed as putting a strain on the engine therefore cheaper cars for me...
#13 stevet4361
stevet4361
  • 78 posts
  • Local Club: n/a
Posted 19 January 2007 - 11:51 AM
Thanks for reply, my 85 ritz is something unusual, I beleive its adequate for my needs, ( the towing weight is under 400kg) , the problem being my car has an ERA bodykit, and the towbars ive seen for the mini seem to take a bit of support from the rear valance? which i would find it difficult to work on, I only want something simple to bolt on and legal, Any help appreciated.
#14 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 19 January 2007 - 12:36 PM
This has been covered before.
The max towed weight is 450kg with a BRAKED trailor, that includes the weight of the trailor. This is documented in the Rover workshop manuals, and granted is probibly for standard 998 engines, however, note it states BRAKED trailor.
As far as the law is concerned, they will use this as the limits as its the only official documented towing weights for the Mini saloon.
#15 taffy1967
taffy1967
    Whovian
  • 9,896 posts
Posted 19 January 2007 - 01:51 PM
Found it.
Yes and Rover didn't bother getting the approval after 1998 since it knew the real Mini was ending soon no doubt?
