Mot Retest- Emissions
15 replies to this topic
#1 aidan8888
aidan8888
  • 57 posts
Posted 04 March 2012 - 10:32 PM
1990 998 rover mini city. Stage one kit fitted.
I took the mini for its MOT the other day and the emissions didnt get tested as the exhaust had a leak, I have now fixed the leak and am taking it for its retest.
As it couldnt be tested the first time i am curious as to how I can get the emissions down as there is no room for it to fail on this test. Any ideas?
#2 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 04 March 2012 - 10:35 PM
Your car should not be tested for emissions as it's a carb engine and is too old to warrant an emissions check.
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 04 March 2012 - 10:42 PM
They should have tested the emissions the first time, irrespective.
A holed exhaust can allow air to be sucked in,
causing artificially low readings.
Where a vehicle has an exhaust holed to the extent
that MOT failure is warranted, the emissions should
be rechecked when the exhaust is repaired even if
the vehicle does not leave the testing station in the
meantime. Owners should be made aware that any
emission readings taken with a leaking exhaust
might be incorrect.
Holes not justifying MOT failure do not normally
have a significant effect on the constitution of the
exhaust gases at the tailpipe and can be ignored
It dos not say in there that the test should be aborted
#4 Sprocket
Sprocket
  • 7,266 posts
Posted 04 March 2012 - 10:46 PM
This is so wrong
any vehicle manufactured after 1st August 1975 is required to achieve basic emissions limits. A vehicle manufactured in 1990 is required to pass an emissions test with the limits of 3.5%CO and 1200ppm HC
#5 Spud_133
Spud_133
  • 1,689 posts
Posted 04 March 2012 - 10:59 PM
I was merely quoting what I learnt at college
#6 lrostoke
lrostoke
  • 6,923 posts
Posted 04 March 2012 - 11:07 PM
sack the tutor then :)
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 04 March 2012 - 11:13 PM
In the absense of any testing gear, wind the nut under the carb upwards anticlockwise when looking from above, if the mixture gets to weak you will hear the engine start to hunt and start popping on tickover, just wind it back down half a turn or so from there. should be ok for the MOT till you can set right.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 04 March 2012 - 11:16 PM
Check the plug colour, that should give you an indication as to whether its running rich!
#9 bmcecosse
bmcecosse
  • 9,699 posts
Posted 04 March 2012 - 11:38 PM
Remove the air filter - and take the car for a good hard blast just before the test.......
#10 aidan8888
aidan8888
  • 57 posts
Posted 04 March 2012 - 11:54 PM
What purpose does removing the air filter serve? Does it make the engine run more lean?
#11 Sprocket
Sprocket
  • 7,266 posts
Posted 05 March 2012 - 12:07 AM
No, it ensures that the engine sucks in all the road crap, so that it'll eventually fail emissions on Hydrocarbons
#12 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 05 March 2012 - 12:14 AM
might be incorrect.
But it does say that the emmissions test should be carried out once a repair has been made.
That's the adjustment for an HS carb, doesn't a 1990 car have an HIF? Which would mean the mixture screw at the side should be screwed inwards to lean out the mixture.
Yes this will make the engine run leaner as there is less restriction into the carb. It will also make the car noisier.
#13 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 05 March 2012 - 12:32 AM
It says rechecked, if it's being rechecked it must have been checked in the first place.
#14 lrostoke
lrostoke
  • 6,923 posts
Posted 05 March 2012 - 07:56 AM
Pretty sure it was the 1275's got the HIF from about 1992 on, this is a 1990....998 should be HS4 unless its been changed
#15 surfblue63
surfblue63
  • 2,539 posts
Posted 05 March 2012 - 11:31 AM
My mistake, only the Coopers got the HIF in 1990, all 998s had the HS4.
