I have had my mini running and it revs on the spot fine but you try to pull away it just dies?? Do you think it could be ignition timing?
I have a 12v supply running straight to my coil but the negative side seems to be live aswell. Is this normal? I'm using the metro turbo electronic ignition set up
Many thanks Rick
Coil Trouble
Rickus
, Mar 05 2012 07:26 PM
2 replies to this topic
Posted 05 March 2012 - 07:26 PM
Posted 06 March 2012 - 01:06 PM
could be too basic but ive had trouble before and it was literally moisture in the fuel, might be worth a look
Posted 06 March 2012 - 09:35 PM
It's a fresh tank and fuel. I properly should have said its a freshly rebuilt engine.
Just don't know what could be causing my issues
Cheers. Rick
Cheers. Rick
