Shot Blast Brake Discs?
Posted 05 March 2012 - 09:05 PM
Would it be a good idea to shot blast them clean or not??
Posted 05 March 2012 - 09:08 PM
Posted 05 March 2012 - 09:09 PM
Posted 05 March 2012 - 09:11 PM
Posted 05 March 2012 - 09:12 PM
A little rust is fine on your disks, happens when its been standing a while. Driving round will remove this surface rust as the pads will wear the surface away to reveal the metal underneath.
Posted 05 March 2012 - 09:13 PM
Posted 05 March 2012 - 09:16 PM
It will get in all the nooks and crannies unlike sanding, don't turn them on a lathe as unless you get them trued up 100% you will end up with effectively warped discs!
Otherwise as said above I'd just use scotch pads as it will only be a bit of light surface rust that won't be hard to remove.
Posted 05 March 2012 - 09:18 PM
what about turning it out on a lathe? would that work, if its cheaper than shot blasting it.
There are lathes that remove the surface of the brake rotors for you whilst still attached to the car. The main purpose of these lathes however is to actually reduce brake judder as the disks had become "warped" or deformed. I would say that it would be complete overkill just to remove the surface rust when all you need to do is brake a few times.
Edited by redhotminilewis, 05 March 2012 - 09:20 PM.
Posted 05 March 2012 - 09:21 PM
Will shot blast damage it then?
Cheers.
Posted 05 March 2012 - 09:22 PM
Cheers.
Yes
Posted 05 March 2012 - 09:23 PM
I would doubt that warping could be caused by shot blasting, and any pitting will be the corrosion that shouldn't really be there anyway.
Turning on a lathe is possible however rust is very hard and can easily destroy lathe tools before they have reached the full cut ie the swept area of one side of one disc
The real question is how much rust is there ??? A photo would be good
Edited by mra-minis.co.uk, 05 March 2012 - 09:25 PM.
Posted 05 March 2012 - 09:31 PM
The best method to remove majour rust and garantee a even and concentric surface on the rotors is using a pro cut on car lathe like the video below.
Edited by redhotminilewis, 05 March 2012 - 09:32 PM.
