Ive got a moped as a run around until my 17th, but its running like a turd at the moment... A little while ago, while I was cleaning it with a pressure washer, some must have got into the engine area, and refused to start... Ever since that day, when the engine is cold, it will stall and have no power until its fully warmed up...
So, I popped the carb open the other day, and found out that both jets were clogged with dirt. I tried to clean them with a very thin piece of wire, but that has made things worse. It now still has no power, will not idle and will not stay running. I also inspected the auto choke, the seal was dirty but I gave it a clean with some WD40.
Do I need new jets for the carb? Or is it something else?
Ben
Edited by fattail95, 05 March 2012 - 10:48 PM.
