Exhausted all resources trying to fix engine
Posted 22 February 2006 - 02:09 PM
Things we checked-
Fuel line blockage, fuel filter, cleaned out and rebuilt carb, AAF needle, blue spring, thin oil- thick oil in dash pot, replaced engine driven fuel pump with electric putting out 3-4 psi, ignition timing 12 btdc @ 1000rpm, changed head, changed valves and springs, changed rocker assembly, checked engine timing (chain slack, but timing dead on), sprayed for air leaks, changed head gasket, checked float level (4.0 mm), changed ground strap...... getting expensive....
Now the problem
No matter what we do the engine is running lean- with the choke FULL OUT!!!!! When you tickle the carb it just cuts right off. :'( - so Im thinking mixture is the answer to the car running like a wet fart.
Wierd stuff
Vented oil cap- BUT when the engine idles and the cap is removed the engine idles very rough. Runs better with the line coming from the oil breather to the carb plugged up.
Engine Specs
1275 "A" not A+ bored 30 over to 1310, unleadded head, headers, RC40, K&N filter, Minispares intake manifold, hs4 carb, 123ignition electronic ignition, standard coil, stock cam.
I was talking to an airplane mechanic and he suggested that the cam might be so worn down that the intake is not opening enough. He suggested i open the oil filter and look for metal. He thinks that the mixture is rich as anything but is not being delivered to the cyl. I have had several mini nuts helping me and they are all at a loss as well
P.s. Just tried to raise the float level but there are no washers to remove from under the jet...........................
Posted 22 February 2006 - 02:35 PM
Posted 22 February 2006 - 03:33 PM
Posted 22 February 2006 - 03:44 PM
Posted 22 February 2006 - 04:03 PM
Have you checked the throttle spindle on the carb to check it is not sticking ? and preventing the bronze coloured (cant remeber what it is called!) flap from opening fully ?
Edit; the spark plug leads are all connected correctly arent they ?
My 2p
Jimmy
Posted 22 February 2006 - 04:05 PM
also it might be worth check the breather pipes on the carb if you have changed the breather to mini kn type (dont know the proper name) then you will have to block the breather pipe thingy on the carb.
sorry if i am telling you how to suck eggs
Posted 22 February 2006 - 04:16 PM
HOWEVER!- dont know if it will help at all, but I found that the tube going to the jet has a slight crimp where it enters the jet... Going to try to round up a new one............
Posted 22 February 2006 - 04:24 PM
Posted 22 February 2006 - 04:54 PM
Just had the car out- 34 flats down from the bridge and.......... LEAN
Posted 22 February 2006 - 08:38 PM
Posted 22 February 2006 - 08:42 PM
Posted 22 February 2006 - 08:45 PM
Posted 22 February 2006 - 08:50 PM
Either there is not enough fuel leaving the carb, or the fuel that is there is going somewhere else other than the cylinder.
What about a leakdown and compression test?
Posted 22 February 2006 - 08:56 PM
Posted 22 February 2006 - 09:07 PM
This could very well be an air leak in the breather system. The mini uses a possative cranckase ventilation system. This pulls a gentle vacuum on the crankase to evacuate any blowby and fuel vapours. if there is a leak in any of the plumming of the breather system it will draw vast amounts of air into the engine as it would if you just disconnected the breather pipe from the carb and left it open. There may be a 'hole' (not litteraly) in the seal of the engine allowing air into the intake of the Engine throught the cranckcase. This will cause lean running. very much like when you remove the oil filler cap, its not sealed but does generate a resistance, also worth noting that these should be replaced on service intervals too.
