Are you any further on with this
Exhausted all resources trying to fix engine
77LeylandMini
, Feb 22 2006 02:09 PM
16 replies to this topic
#16
Posted 24 February 2006 - 09:40 PM
#17
Posted 25 February 2006 - 12:45 PM
dont know if this helps but I thought the level of fuel in the float chamber had to be about level with the jet- in this case it is not, but like I had said the needle can not be raised any more- unless you have some suggestions?
Nope 'because then the jet would overflow into the jet bearing when the choke is used.
Are you still using that 1/4" fuel line? I really am sure it should be 5/16".
The dodgy jet feed sounds like a good thing to investigate.
