thermostat sensor???
Posted 22 February 2006 - 07:26 PM
bro thinks i have twisted the wires on the thermostat sensor
could this be right or what do u think it is?
if it is the thermostat sensor how much would a new one be?
cheers
Posted 22 February 2006 - 07:33 PM
The standard yellow fan thats attached to the water pump, next to the belt that goes round the alternator, should always be on.
Posted 22 February 2006 - 07:38 PM
its a 91 its a carb and its the main large fan on side of radiatorWhat year is your car? Is it an Mpi or carb? Are you talking about the yellow (standard) fan in front of the radiator, or the electric fan in the wing?
Posted 22 February 2006 - 07:58 PM
Posted 22 February 2006 - 08:03 PM
Posted 22 February 2006 - 08:09 PM
then i think you will find that, that fan is belt driven and it should always be on.
oh right.................im sure it was constantly on when i first had the car? only had it a couple of weeks,
Posted 22 February 2006 - 08:20 PM
Posted 22 February 2006 - 08:40 PM
what fan kicks in then when the temperature goes up? if its not that one?
Posted 22 February 2006 - 08:41 PM
Posted 22 February 2006 - 08:47 PM
If you cooling system is in good nick, that should be all that’s needed
Some earlier minis, mine included only had the yellow fan bolted to the water pump pulley
Works fine as long as you have the right amount of antifreeze in the system
and the fan hasn’t been put on backwards
Posted 22 February 2006 - 09:05 PM
the one on the right of the rad in the inner wing.
yup found that one, sorted no worries!
mini seems to be wyning read some previous threads and most of u say it is water pump, probably that? how easy is it to fit?
Posted 22 February 2006 - 10:11 PM
