Yes, its a shame that I have to rectify with a new gasket etc. But just one of those things really. Its a days worth of work including driving and resetting valve clearancance etc etcThat's a shame John. There is nothing I can add to the advice given above.
Cylinder Head Nut Leaks Coolant
#16
Posted 10 March 2012 - 04:21 PM
#17
Posted 11 March 2012 - 06:30 PM
Today I removed the cylinder head etc, and have removed all the cylinder head bolts and what I found was very surprising. All of the threads holes for the shorter studs go through to the water jacket!! The holes for the longer studs are all blind threaded holes.
It is obviously like that intentionally as the whole of the hole is open to the jacket (not corroded) (a through hole). I am thinking there can be to reasons for this:
- The engine builder made a huge blunder if he has worked on the threaded holes at the top of the block.
- This this is an early 1960 engine, perhaps they were made this way and the threads on the studs needed to be sealed. And perhaps a design change meant that future engines would have blind holes for all of the cylinder head studs.
John
Edited by mk=john, 11 March 2012 - 06:33 PM.
#18
Posted 11 March 2012 - 06:59 PM
#19
Hi
It is obviously like that intentionally as the whole of the hole is open to the jacket (not corroded) (a through hole). I am thinking there can be to reasons for this:But the thing I am worried about, is what do I do now? Will the `Red Hermitite' sealant mentioned by Cooperman earlier in this thread seal the threads?
John
That is indeed very odd. The red Hermetite should seal it all up. I've never encountered this before, even on early cars, but the '11th bolt' on the 'S' often broke through to the water jacket and a smear of sealant usually sorts this out.
All you can do is to give it a try really.
#20
Posted 11 March 2012 - 08:58 PM
It's very odd to me also. I have another spare MOWOG engine from an early car (I cant say how early), and all the stud holes on that are blind holes. i checked today.
For the engine in my car, it seems this was intentional, wether it was an early design flaw rectified on later engines I just dont know. I have no reason to think why the engine builder would make these through holes, that would obviously be a huge mistake on his part.
I will try the Red Hermitite to seal the threads, as that is my only option. Will do that next weekend and keep posted
John
#21
Posted 11 March 2012 - 09:09 PM
I am kinda now thinking this was intentional on my very early engine, and modified on later engines to have blind holes as having all five shorter studs breaking through would have been highly improbable.
Edited by mk=john, 11 March 2012 - 09:12 PM.
#22
Posted 11 March 2012 - 10:07 PM
#23
Posted 11 March 2012 - 10:17 PM
#24
Posted 11 March 2012 - 11:06 PM
Let us all know how you get on with the job.
#25
Posted 12 March 2012 - 08:54 AM
At least one of my Minis, the 1976 model, had some stud holes which broke through into the water jacket, so I assume it is quite normal. Either the castings or the drilling depth, or both, may have been a bit variable.
#26
Posted 12 March 2012 - 06:38 PM
Thanks for the info all of you.
Tiger99, thanks for info about your 76 mini. I guessed this must have been design intent on this particular block on my car, but now after reading on the internet about all the many other brands of engines that can have the studs going through the water jacket, I am happier!
John
#27
Posted 18 March 2012 - 01:24 PM
I have now replaced te cylinder head, and I have used new studs, using `hermitite red' on the threads to seal them on the block. I took the car out for a 50 miles run this morning, and the leak has now gone, so I am much happier.
Spark plug colour is buiscuit brown, runs like a gem!
Now that the car had done 50 miles since cylinder head replacement, its time to retorque it and reset valve clearance......thats a job for tomorrow.
Thanks for the help. I'm now well happy!
John
#28
Posted 18 March 2012 - 02:25 PM
