Sound Proofing
23 replies to this topic
#16 Brams96
Brams96
  • 2,308 posts
Posted 09 May 2012 - 02:02 PM
Yeah me too, we've got it in some of our A/C units at work. It squashes down when pressed but springs back well & is dense too so good noise absorbsion qualities.
#17 williamwalters
williamwalters
  • Just Joined
  • 35 posts
Posted 10 May 2012 - 04:22 PM
thanks, ill take a look at that
#18 joakwin
joakwin
  • 958 posts
Posted 12 May 2012 - 01:30 PM
that foam stuff looks pretty nice, maybe some flat sheets of that on the floor and firewall
so far i got nothing but dnyamat extreme bulk packs in my car
#19 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 13 May 2012 - 09:59 AM
As (at the time) I was on a very strict budget, having just bought my car - T&T on the road, only for it to cease to be 5mins later with a shopping list of problems (gotta love Mini's), I went with the flashing tape route and added some closed cell unbranded foam from eBay.
Topped off with carpet underlay.
Pics here:
http://s1105.photobu...fing and Audio/
Completely unhelpful and pointless, gratuitus video:
(May have to skip to 35seconds, it's still editing in youtube - apparently)
#20 zinzan
zinzan
  • 373 posts
  • Local Club: me and my imaginary friend
Posted 17 May 2012 - 04:07 PM
Just put in a product called Fatmat in mine. Reviews say it's not as good as Dynamat, but its a lot cheaper also. Going to try it and see how it goes. Anything will be better than the rotted bit of carpet underlayment...
#21 zinzan
zinzan
  • 373 posts
Posted 17 May 2012 - 04:10 PM
And it the Fatmat doesn't actually reduce the noise, it's sticky enough to at least hold all the body parts together!
#22 construction.mini
construction.mini
  • 56 posts
Posted 18 September 2012 - 03:35 AM
Do you guys not have access to Ebay.com order sound deading from there..... FATMat is pretty good stuff..... Just relized how old this topic is awwww welll
#23 kappa
kappa
  • 1,301 posts
Posted 10 October 2012 - 10:30 AM
Has anyone got an idea of how much is needed to cover the whole car, bare in mind mine is a clubby estate
#24 freshairmini
freshairmini
  • 1,718 posts
Posted 15 October 2012 - 02:30 PM
This was posted a while back in answer to that exact question.
I've used 84 SQ.FT in/on mine.
48sq ft of Dynamat Superlite
36sq ft of Dynamat Extreme
Then under the bonnet I've also used dynaliner.
This did include the roof though.
This being ruckus i'm sure he properly covered every possible expanse on metal! :D
I would advise that you buy a pack of sound deadening, be is silent coat, dynamat or what ever you choose, and see how you go. Idea being, when you run out buy some more! Until you got as much coverage as you want.
Edit: Just realised you said clubby estate, you will need more, but as I said start with one or two packs and buy more if needed.
I believe the 4mm silent coat (bulk pack), comes with loads of sheets, enough for 24sq ft. So two packs of those would be enough to get you started, but its not cheap by any means O_O
Edited by freshairmini, 15 October 2012 - 02:31 PM.
