Replacing Engine Mounts.
#16
Posted 02 April 2012 - 09:08 AM
Your vibration is very unlikely to be due to the engine mounts. You should consider very carefully whatever other work you have done recently, to see if that could be the cause.
#17
Posted 02 April 2012 - 11:33 AM
#18
Posted 02 April 2012 - 06:42 PM
All the stuff that you might expect with the engine loose.
#19
Posted 03 April 2012 - 04:34 PM
#20
Posted 04 April 2012 - 09:41 PM
I have E.T fingers so that made it a bit easier.
Have you thought about replacing your brake pipes at the same time? Much easier to do with the rad off, I would also think about a coolant swap.
#21
Posted 04 April 2012 - 09:45 PM
i have to do this son when my mini returns from getting a respray could this be done easyer if it was on the small ramps you get then jacking the engine up fomr there ?
I found axle stands to be fine, just gave a bit more clearance and the ability to take the wheels off.
I am about to tackle this job myself today...I have the mounts and i cant crack on with anything else yet so ive decided to do these.
In the haynes it says for the drivers side mount that a lot of stuff needs removing and to jack the car up and put it on axle stands.
My drove slopes towards the road..will i be able to do it without the axle stands as above??
cheers
On the drivers side I managed to tackle it with just removing the washer bottle, but I have long skinny fingers!
#22
Posted 08 April 2012 - 12:46 PM
The mounts are not too thick, they need to be like that, and settle down properly after a while.
After your post I have decided to check other things, the engine itself is a very sweet 23k unit original to the car. Timing and mixture is spot on and to touch the engine when idling you can feel its not creating lots of vibration. I had put MPI steady bushes in the top steady and renewed the bottom steady bushes for normal genuine rubber items. I could not work out why the vibration at idle is rattling everything, So I replaced the top engine steady bushes for normal rubber items which made no difference.
I have now bought and installed another set of mini spares engine mounts and they seem better. Although they are compressed when fitted it is as much as I would expect and the vibration is reduced greatly. Re-installing the MPI top steady bushes has caused no increase in vibration. I can only conclude one or both of the old mounts was to hard or too thick. At least I can sit at traffic lights without pulling my hair out.
#23
Posted 07 September 2016 - 06:24 PM
Any one any experience with the MPI air conmini, lots of stuff in the way, I would like to do it from underneath... answers on a post card please!
#24
Posted 07 September 2016 - 07:36 PM
I've always found it easier and faster if you remove the Clutch Cover on that end and the Radiator of that end to change them out. They can be done with these in situ and I have tried that, but found it less frustrating to do it the way I've mentioned here.
#25
Posted 08 September 2016 - 11:13 AM
They are intentionally designed that way so that the rubber is loaded correctly when they are in place.
