Small rust hole in wing
Posted 25 February 2006 - 11:17 PM
I pushed through 5 little ones altogeather, there about the size pencil at the most.
Do i need a new wing or would i be able to fill the holes just to last a year or so til i can afford to replace the wing and give the car a full respray.
Any help would be super
Cheers lee
Posted 25 February 2006 - 11:51 PM
Posted 26 February 2006 - 12:14 AM
Put some duck tape on the back of the panel to stop the filler falling through
Prime then paint
But it’s more than likely that the rust will show trough the filler making it look worse within a month or two
Posted 26 February 2006 - 12:17 AM
You could use filler
Prime then paint
Or weld it up for a proper job, just filling a hole is a crappy bodge!
Posted 26 February 2006 - 12:18 AM
So i suppose if i drill the holes out slightly larger ie back to good metal that should hold for a while.
cheers lee
Posted 26 February 2006 - 12:25 AM
Just make sure you use good quality filler
As the one I used to smooth over the joins in my front panel has cracked and allowed water to attack the sound metal behind
How 2 use body filler
Posted 26 February 2006 - 12:26 AM
Cheers karl
cheers lee
no, water will get in, and they will rust even more...
don't worry though, I have never done anything like this before....you carry on LOL
Yep should do
This what it now looks like :'(
thats why you shouldn't give advise on bodywork LOL
Posted 26 February 2006 - 12:37 AM
All the other times I have used filler it’s been fine
Posted 26 February 2006 - 12:45 AM
Like final smoothing of my doors, rear panels and the dint in my boot lid
Done over 8 months now not a hint of bubbling
And I take you know someone or work in a body shop then?
filler is for removing ripples and dents from panels, not for repairing holes.
As for me, I know alot of people, and I don't work in a bodyshop, but I DO know how to repair cars properly and have been for the last 10 years....
Posted 26 February 2006 - 01:09 AM
Posted 26 February 2006 - 02:48 AM
Posted 26 February 2006 - 08:36 AM
that wont work either , the seams flex as said in a previos post , the steel will crack either side of the welds after a bitOr weld em up and grind em back!
