Arc Welder?
Posted 29 March 2012 - 05:20 PM
Kinda new to this kinda thing, thanks in advance.
Posted 29 March 2012 - 05:26 PM
Posted 29 March 2012 - 05:31 PM
Posted 29 March 2012 - 05:43 PM
Posted 29 March 2012 - 06:14 PM
I have no idea how he does this. Must be magic.
Al
Posted 29 March 2012 - 06:22 PM
You can get attachements to reduce the amperage of an arc welder from http://www.frost.co....attachment.html
They also sell a low amperage arc welder.
Posted 29 March 2012 - 06:50 PM
My mate can. he is an absolute genius. Hes a machine fitter of some 35 years experience and ive seen him seem weld a mini boot floor beautifully with an arc welder. He won't entertain a mig.
Al
It's witchcraft!
Posted 29 March 2012 - 06:53 PM
It must be just gave two bits of sheet a go, just blew holes in it on its lowest setting.
Al
It's witchcraft!
Posted 29 March 2012 - 07:03 PM
Posted 29 March 2012 - 07:05 PM
i have a mini sip welder i think thats what its called and it has a setting for 1.5mm and it works pretty wellIt must be just gave two bits of sheet a go, just blew holes in it on its lowest setting.
Al
It's witchcraft!
Posted 29 March 2012 - 09:28 PM
You will be able to weld the 1.2mm thick panels, just, but it really is not viable on the majority of the panels which are only 0.9mm.
Posted 30 March 2012 - 04:44 PM
wouldnt cut it exactly the size i would leave a extra overhang on nearly all the sides then weld its but you will have to be very carful, also keep in mind that it is really hard to strike an arc at some angles so make sure you have plenty of room to around the place that need welded, i tryed welding from underneath the car when it was jacked up and i could barly get a good arc to weld haha
So i cut the repair panel say 10mm wider allround weld top and bottom joints? Am i correct in saying that?
Posted 30 March 2012 - 05:53 PM
Posted 30 March 2012 - 06:37 PM
There no real reason to use one now, MIG is cheap enough, gives better results and is easier and quicker to use.
Buy a mig, use it a few times and then stick it on ebay, you won't lose much money and you'll have saved a fortune paying other people to do it for you.
Its also important to note that your life may depend on your welding one day, ground back bird crap ,can be made to look ok but its still going to be a weak joint. I don't like grinding welds back to nothing as it weakens the join, just flash the top off and leave it.
Posted 31 March 2012 - 11:48 AM
wouldnt cut it exactly the size i would leave a extra overhang on nearly all the sides then weld its but you will have to be very carful, also keep in mind that it is really hard to strike an arc at some angles so make sure you have plenty of room to around the place that need welded, i tryed welding from underneath the car when it was jacked up and i could barly get a good arc to weld hahawouldnt cut it exactly the size i would leave a extra overhang on nearly all the sides then weld its but you will have to be very carful, also keep in mind that it is really hard to strike an arc at some angles so make sure you have plenty of room to around the place that need welded, i tryed welding from underneath the car when it was jacked up and i could barly get a good arc to weld haha
thats what i would do it leaves room for some small error, but shifty is right
