hi,
my rear windscreen rubber is falling appar and i need to replace it as it is letting water into my mini, how would i go about doing this?
Adam
Rear windscreen rubber
mini mad adam
, Feb 26 2006 06:41 PM
3 replies to this topic
Posted 26 February 2006 - 06:41 PM
Posted 26 February 2006 - 06:44 PM
take centre filler out of rubber.
Grab a helper, and push the window out of the rubber.
Put new rubber round edge of screen
Run string inside new seal
Push one corner of window & seal onto frame
Pull out the string away from the window and it should pull the seal lip onto the frame.
Put in new filler piece.
Posted 26 February 2006 - 07:05 PM
thanks alot mate, helps alot.
Posted 26 February 2006 - 07:17 PM
It sounds easy, but if you've not done one before, make sure there's no small kids around 'because you will do a lot of swearing!
