Ok but remember that your poor little 45amp alt is not designed to produced 45amp all the time. And once you run down BOTH batteries that little alt is going to have to do a LOT of charging to get them 100% again.
I burnt out the stock 90amp alt in one day with just one Exide 900DC, as it was so flat (10.2 volts) it took hours to charge it, I was also running the system at the same time. Poor alt didn't stand a chance (not driving = air flow = hot hot hot)..
You can get Split charging kits that have a over ride switch to link the batteries if wanted or select which one gets charged.
All that said I'm currently running 2 Exide's in
parallel, but going to put in a 200amp breaker so I can separate the batteries.So it will work like thisBefore going to anywhere where I will run the system stationary for any length of time both batteries will be fully charged.I have a C-tek charger with a linkup cable under the car permantly wired in so I can just plug it and leave it changing. While driving both
batteries will be left linked in.
When running the system
stationary for any length of time I will break the breaker, this leaves the system running off the slave battery only, and the cars other systems still linked to the main battery.
As the main battery has not been used it should be 100% (my headunit does not need the ignition on) and re-linking the batteries (when I'm about to drive again) will be safe as it will only be one that needs charge.Simple and if I ever do need to run both in parallel I can.
