Hi guys! Bit of a noobie on here i know so bear with me please :)
Basically i've bought a 1992 sprite with no engine, now i know originally they we're a 1275 but i'm building it up for my girlfriend who is learning to drive and so i've got a 998 to go in that i recently got hold of from a 88' metro.
Now i know the clutch was a cable assembly so i'm replacing the clutch arm and fitting the slave cylinder bracket and i also know about the difference with the cylinder heads regarding the bypass hose and thermostat housing. I've got a spare 998 head to go on (with bypass), a new mini water pump to go on, with the bypass hole and a mini thermostat housing.
I just wanted to know if there was any other differences i didn't know about or if there was anything wrong with what i'm doing already!
Please let me know!
Rich
p.s - The sprite did originally have a carb! I checked its got a choke cable! ;)
Metro Engine Into A 92 Shell, What Needs Doing?
teamjellybeanmini
, Apr 05 2012 05:02 PM
No replies to this topic
