SPI Idle control Stepper Motor
Posted 27 February 2006 - 09:22 PM
If I take the little rubber boot off the stepper motor there is a thin shaft, maybe 3mm diameter but it only seems to stick out about 4mm so not even right out of the rubber boot.
Does this sound right or is there something missing?
Posted 27 February 2006 - 09:58 PM
dave
Posted 27 February 2006 - 10:01 PM
If so I already tried that and it didn't do anything.
It all worked fine before I took the inlet off which is quite annoying
Posted 27 February 2006 - 10:08 PM
also have you adjusted it as in the little lever thing at the back when you reset it?
dave
Posted 27 February 2006 - 10:14 PM
Adjusted the lever thing? is that the adjustable 'plate' which makes contact with the stepper motor ram?
If so, even if I adjust it all the way out then it still won't touch the stepper motor ram. With the rubber boot on you can't see the ram from the stepper motor at all.
Posted 27 February 2006 - 10:43 PM
See how you get on
Also worth noting that when the ignition is switched off the stepper motors to full step positions ready for the engine to start the next time. This can be heard as several clicks coming from the engine bay.
it may be that you do actualy need to tune the system with a diagnostic, but not being able to see whats going on its going to be difficult to diagnose.
I helped msisleman out the other day. the stepper on his was at zero steps and the idle was up at around 1000, the whole system needed to be re tuned. Just waiting on confirmation on the other problems he had to resolve
Posted 27 February 2006 - 10:48 PM
Posted 27 February 2006 - 10:50 PM
Posted 27 February 2006 - 10:52 PM
Posted 27 February 2006 - 10:55 PM
Posted 27 February 2006 - 10:58 PM
Posted 27 February 2006 - 11:15 PM
The stepper can be removed from its housing and you can see the cam inside that operates the plunger moving. If you go this way, remove the torx screws only, there are three posidrive screws that hold the motor to the lid, leave these.
One other thing is to try and reset the ECU. Not had any sound information that says this actualy works but might be worth a try. The stepper may not be motoring because the ECU is telling it not to as the ECU had tried to adapt to the incorrect tune of the throttle. Disconnect the ECU from its connector for a few minutes then reconnect it. This should (suposedly) reset the adaptive values.
I'll ad some piccys in a bit
Right, to remove the stepper motor from its housing, it is necsisary to remove the injector and regulator housing first.
Clamp the hoses
Then disconnect the unions with a 15mm and 17mm spanner
Then remove the four large torx screws
And withdraw the housing
The four torxs crews for the stepper can now be removed, note two also hold the linkage bracket
Here you can see the plunger, the cam and the motor clearly
This is another manifold i have. I have removed the rubber boot to give you an idea as to where it should roughly be position wise.
Edited by Mini Sprocket, 27 February 2006 - 11:53 PM.
Posted 27 February 2006 - 11:20 PM
Will try resetting the ecu as well, easy to do and if it just might work it's got to be worth a go.
Posted 27 February 2006 - 11:56 PM
Posted 28 February 2006 - 07:31 AM
Luckily I have a day off on Thursday si I will be able to try all these suggestions and see if it cues the problem.
Thanks for all your help, some real useful knowledge and always happy to offer it.
