Refitting The Dizzy
Posted 10 April 2012 - 09:40 AM
Do i need to dismantle the dizzy or is it best left alone if it was working fine?
When i refitted i lightly oiled the end of the spindle to the bit im guesssing connects to the camshaft does anything else need lubing?
i dont have markings to position the body to the block correctly how can i ensure it is lined up correctly.
The engine should be at tdc i followed andyminimads engine build thread.
let me know what you think.
Posted 10 April 2012 - 09:44 AM
Posted 10 April 2012 - 09:46 AM
not sure which dizzy i have except its lucas.
Posted 10 April 2012 - 09:56 AM
Posted 10 April 2012 - 09:57 AM
The dizzy will only fit one way, your drive gear looks about right in the block.
look at how the dizzy cap will fit, and with the vac unit on the left No 1 HT lead should be roughly 2 oclock position
Point the rotor arm so its facing roughly 2 oclock the place where No 1 HT is on the dizzy cap,then slide the dizzy into place, twist the rotor from side to side until the dizzy slides fully into place.
If it was working ok just refit
I'd replace that rotor arm though looks pretty
you will need to retime the dizzy though
EDIT: Steve... language.
Edited by dklawson, 10 April 2012 - 12:12 PM.
Posted 10 April 2012 - 01:19 PM
retime the dizzy. Is this with the strobe timer? do i need to do it before intial startup or can it wait till rolling road?
Posted 10 April 2012 - 01:31 PM
If it doesn't if you can get some body to turn the key whilst you turn the dizzy slowly in each direction, you should hit the sweet spot where it starts.
Just make sure you don't have damp hands :) HT leads can give off a good shock
Then you use a strobe.
Edited by lrostoke, 10 April 2012 - 01:31 PM.
Posted 10 April 2012 - 01:39 PM
Be carefull with HT leads, ground strap and battery cable, i nearly fried myself once when the battery cable snapped..
Posted 10 April 2012 - 04:26 PM
jaydee sorry advance what the crank pulley? what purpose does this serve?
Posted 10 April 2012 - 04:36 PM
To be honest your not going to get an exact static timing point with the electronic dizzy, so you may as well fit as close as poss then twiddle with it whilst cranking the engine.
As you turn the dizzy you'll hear the engine try start and when its close to going
Edited by lrostoke, 10 April 2012 - 04:38 PM.
Posted 10 April 2012 - 06:32 PM
Posted 10 April 2012 - 06:59 PM
Posted 10 April 2012 - 08:04 PM
2 man job, one in car turning key and fiddling with choke, other just slightly adjusting dizzy back and forth till it fires
Posted 10 April 2012 - 09:02 PM
Posted 11 April 2012 - 05:48 PM
