It supports the main positive power lead to the starter (on pre-engaged starters) which runs from the battery.Fixes to the threaded hole in the drop gears casing,just behind the horn.Should have a rubber grommet in it to protect the wire. Actually the grommet stays on the wire and just slides into that bracket,hence the open side to the holeoh and this bit was with the dizzy not sure why i did it what and where does it go?
Edited by Pigeonto, 11 April 2012 - 08:10 PM.
