Rear Camber Adjustment:- Standard Outer Radius Arm Bracket
Posted 25 April 2012 - 08:56 AM
I've got a rear wheel that's well +ve camber. We have changed the radius arm and it's still drunk, so I'm going to fettle the bracket. There are lots of posts on the forum that this is the best solution for a daily drive, but none spell out exactly what to do. I presume I'm filing the single large hole in the bracket. The one through which the trailing arm fits, the bracket seems to be strengthened here. I intend to file this so I can lift the end of the training arm.
I know it will be a process of trial and error, but does anyone have some idea of a starting point. I read in one post that someone increased the hole by half an inch to get a 0.5 degree improvement. (I hope he's wrong because I may need to go all the way through the bracket before I get my wheel straight).
Once set I'll tack weld a large washer onto the bracket to keep the thing fixed
Posted 25 April 2012 - 09:08 AM
then lifted the wheel up as hard as i could
so shaft hitting where i filed to
and tightened the nut to about 70lbs
its given me about 1/4 deg camber
ive used soome of those bought ones and they broke
mind you my wheels had a lot of pos camber to start with
Posted 25 April 2012 - 09:26 AM
Posted 25 April 2012 - 09:59 AM
Posted 27 April 2012 - 09:08 AM
Got all setup to do the job over the weekend. Car currently an axle stands whilst I let the penetrating oil do its stuff on all the bracket bolts. Just thinking the next step through. Do I have to loosen the inner end of the trailing arm before repositioning the outer end in the modified bracket or will it be OK to refit the outer bracket without touching the inner end of the trailing arm.
Also, should I take the shock offf the trailing arm before removing the bracket or can I leave it on
As I said in original post lots of advice that modifying the bracket was the thing to do, just never found a post which spelt out the process.
Posted 27 April 2012 - 10:25 AM
After filing to the right amount it is best to MIG-weld a large washer to the bracket to strengthen the bracket and hold the dimension correct.
Posted 27 April 2012 - 10:40 AM
Is it OK to remove the bracket without first removing the rear shock ?
Posted 27 April 2012 - 10:47 AM
Posted 27 April 2012 - 11:03 AM
Posted 27 April 2012 - 11:07 AM
had a hell of a job gettting mine back on and lining up holes
that mount thing for subframe was in the way
getting the bracket off. as i say mine was showing pos camber at least 1 deg pos
on the rear. in my opinion 1/8" will prob not be enough
see if i can get a photo
Posted 27 April 2012 - 02:57 PM
You file exactly 1/8" first of all in order to give you a 'calibration' figure. Then re-fit the bracket and 'nip up' the 4 off bolts, lower the car and re-measure.
If you can lift both sides of the car equally at the same time and lower it equally the camber will be as it will be on the road. If not, you need to drive the car backwards & forwards a bit to settle the suspension. The final height of the car relative to the wheels doesn't matter as the rad arms are true training arms and the camber does not change as the car is raised/lowered.
It's a nice little job to do - easy and satisfying when done correctly.
Posted 27 April 2012 - 03:34 PM
Posted 27 April 2012 - 04:14 PM
You could draw a full scale (or bigger) plan: an arc the length of the arm's swivel pin. Draw a couple of radii separated by the desired change in camber angle and measure how far apart they are along the arc to see how much filing is likely.
Posted 27 April 2012 - 06:01 PM
just by looking from the back and bending down
just slightly leaning in at the top is good
well i can tell - maybe its from my racing days
as cooperman says should come off easy did off my race cars
but this road car i have now had to drop shocky and
loosen rear nut on arm and then lever radius arm out
to pull off
