Alpine Spg-13Cs Component Speakers
Guest_TicTax_*
Posted 27 April 2012 - 01:17 PM
By the way, I know nothing about installing ICE and didn't actually want component speakers but it's what I have (long, boring story).
TIA
Posted 27 April 2012 - 01:49 PM
Ideally components should be run with an amp to get the best out of them though.
Posted 27 April 2012 - 01:54 PM
You bought the better sort of speakers, believe me.
Guest_TicTax_*
Posted 27 April 2012 - 02:14 PM
Run the head unit feed into the crossover box and then there should be an output from the crossover box to the speaker and one to the tweeter.
Thanks - I can tell that what was hoping was going to be a quick, easy and relatively cheap installation is going to morph into something altogether different...
Posted 27 April 2012 - 02:43 PM
Its all subjective, One man's simple is another man's labyrinth.
Good luck and keep coming back for advise.
Are you going to start and build/install thread ?
Guest_TicTax_*
Posted 27 April 2012 - 08:29 PM
Not sure what I'm putting in is exciting enough to warrant a thread though - I had a Pioneer MVH-8300BT which I am taking back due to the fact I hate it and have replaced it with an Alpine CDE-133BT but I'm not really into a huge sound system - I have that in my other car
Posted 27 April 2012 - 09:01 PM
Power is nothing without control, and understanding.
The best 'mini' systems are simple.
Guest_TicTax_*
Posted 28 April 2012 - 03:02 PM
Is this a stupid idea and if not, does anyone have any recommendations as to the best type of wood to use and the thickness of it?
Posted 28 April 2012 - 05:22 PM
But why not install them in the correct position... Up front.
Guest_TicTax_*
Posted 28 April 2012 - 10:21 PM
Posted 29 April 2012 - 09:49 AM
Guest_TicTax_*
Posted 29 April 2012 - 10:15 AM
I was merely trying to reuse what was already there. If I was being truly lazy, I would just leave the existing speakers in place rather than think about how best to install the new ones but as it is, I've already started looking at speaker pods.
By the way, no offence taken
Posted 29 April 2012 - 10:22 AM
Don't worry about drilling the parcel shelf its easy enough
Posted 01 May 2012 - 03:02 AM
I'm no expert on this and i'm pretty sure its best to have the 2 close together. But what about mounting the speakers in the rear shelf, crossovers out of site on the underside of the shelf and then tweeters up front?
Sorry to point out the obvious, but you're right there. Why would you say your 'pretty sure its best to have the 2 close together' then in the next sentence suggest you have the speakers in the parcel shelf & tweeters up front, 6 feet away!!? Stop trying to confuse the OP with 'advice'.
TicTax - In the link you first posted the pictures show the connections on the crossover, just connect + to + & - to - for each wire & you wont have any problems. One tip for the parcel shelf if you use 12mm MDF is you will need to champfer off the edges on the window side, especially in the corners, to get the wood to fit in properly. 9mm would be strong enough & slightly lighter too.
Posted 01 May 2012 - 08:15 AM
Like I say, i'm sure i've read before that they need to be close together; but what about mounting them separately? What happens then, and why not do that?
