1981 Hl Project Orange
58 replies to this topic
#31 Mini-Mad-Craig
Posted 09 January 2013 - 02:33 PM
Some awesome fabrication and welding there mate, well done. That is one AWESOME looking Mini :)
#32 danotje21
danotje21
  • 38 posts
Posted 14 January 2013 - 12:05 AM
So got some more done on the pattern panel front end. While they are cheaper, I think you have to be prepared to do some work in order to get them to fit. Anyway, here's today's update:
Headlight retaining ring not looking too good here after adjustments
So I removed it
Tweaked the wing
Spot welded and dressed it
Then went about reattaching the retaining ring
Welded and dressed
Same problem with the flange on this side, soooo....
Had to remake the front half this time, though, since it was pretty rough
Also had a bit of a gap problem, so I sectioned and folded the inner wing flange down to allow for spot welding the wing. While it looks wonky right now, I'll massage it so it looks fine once I get some more welding wire.
Started welding the flange on, but ran out of wire. So here is a partial weld and the wing as it sits on the body.
Spent all day in the garage which was good. All that time was spent working over a new panel which was not good. Still, it's beginning to get there. I'll get some wire tomorrow so I can keep pressing on. Thanks for looking!
#33 PNL629G
PNL629G
  • 48 posts
Posted 14 January 2013 - 01:22 AM
Nice fabrication work going on there - great project! Thanks for sharing.
#34 ba-tat
ba-tat
  • 53 posts
Posted 14 January 2013 - 09:20 AM
This is a great thread with some excellent pictures. Danotje, I really like the way you show us some of the problems you've encountered and how you adjust your approach. I do have some serious garage envy though...
Did you build your bench yourself or buy off the shelf? I'm at that stage myself.
#35 danotje21
danotje21
  • 38 posts
Posted 14 January 2013 - 12:03 PM
Thanks for the comments. That's one of the reasons I joined the board which is for me to feel compelled to keep updating for you guys. Kind of like a workout partner. You don't always want to go, but you don't want to let anyone down. Makes it more fun that way and keeps me going. It's also fun to look back over my progress for inspiration.
Ba-tat--the bench and shelving are actually a little of both. Workbenches of any consequential size are REALLY expensive. I found this product by 2x4 Basics which is all the black plastic end pieces in the picture. Essentially, you buy a kit of whatever you want to build (in this case a workbench), and then you design/build it to your specs using local store lumber. Really is a great product because it allows you to make whatever you want. I think I spent about $150 to build an 8' x 3' bench with a pegboard back. By contrast, a solid wood, 6' x 2' bench from Harbor Freight is around $200. Metal stuff, forget about it. As luck would have it, we also replaced our flourescent kitchen light with multiple cans, so I repurposed the old light in the bench. The plastic is super strong, too, so the bench is nearly indestructible. I'd do it again if I needed another one later (which I would like to have a smaller one for parts, etc). Really is good stuff with lots of ways to customize it for your needs.
#36 Nossedout
Nossedout
  • 160 posts
Posted 14 January 2013 - 07:42 PM
goodluck with the build!
#37 danotje21
danotje21
  • 38 posts
Posted 21 January 2013 - 12:55 PM
Just a minor update this week. I say "minor", yet I spent the last two days in the garage cutting, welding and grinding. I'm finally getting around to fixing a lot of small issues that needed to be attended to before fitting the wings. These aren't terribly interesting, but I thought I'd post them in case someone else is dealing with something similar. Here goes...
So, had the passenger side wing channel fitment issue last time. Just not enough space to reattach the flange and weld it to the car.
So I flattened what was there.
By far one of the simplest, but coolest tools...the air punch. One side punches holes for plug welding, the other acts as a mini press to straighten things. Highly recommended as it saves a ton of time drilling.
Added some metal.
Slotted it to make the bend upward.
And nearly done
Here you can see the holes punched into the wing using the aforementioned tool. So easy and fast. Think the tool cost about $20.
Next, the A panel flanges on both sides simply were not up to snuff.
So I sliced them off and built new ones. I think I've become king of the flanges as I've had to repair a lot of them.
Another great tool...a piece of copper tubing from the hardware store flatted on one end. The welds won't stick to it, so it works great as a backer to larger gaps. Instead of cutting out patches to fit the area, I use the copper tube behind the gap and fill it with weld, then grind it smooth. Works great.
This is where I ended due to going to dinner with some friends. The flanges are overly large at the moment, but this gives me a solid spot to mount the wings on to. Once they are on, I'll grind them down flush with the wings' flanges for a nice uniform look. Surprising how much stronger they make the A panel. Next update will hopefully see the wings as part of the car. Then I'll tackle the hood pins :D . As always, thanks for looking, and I appreciate your comments.
#38 danotje21
danotje21
  • 38 posts
Posted 27 January 2013 - 11:55 PM
Got a few more small things sorted in preparation for the wings. One of them, the scuttle end, is actually a do over as it required rework after messing about with the wing. All is good now, and the wings pretty much fall into place without much work. The gaps are also very nice now, too. Anyway, here's a few pictures.
Pre-spot welded, gaps a little off
Fully welded and dressed
Also had this little guy to put in.
I remember when that area was just a hole. Nice to have something done. I also couldn't resist tacking on a bit of the brightwork after putting it all together again for a fit check.
Looks awesome! I find I do this a lot :) Anyway, that was it for today. Next outing will see the wings become permanently attached. I'll then work on the hood pins and seal the gaps. I still have the right side outer sill to tack on, but I wanted to seal inside before doing so. Now that I have a few things to seal, I can just do it all in one go. Saves the sealant from drying in the tube.
That's it for this update. Cheers!
#39 markje
markje
  • 183 posts
Posted 28 January 2013 - 08:59 PM
Amazing job
#40 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 28 January 2013 - 09:07 PM
Some good work going on there, loving the fab work its good to see. I think you are having the same issues as i had with Project Erm. What looked okish turned out to be a massive can of worms.
#41 danotje21
danotje21
  • 38 posts
Posted 29 January 2013 - 11:37 AM
Thanks guys. Yeah, I initially took it on thinking it would be relatively easy. I had to learn to weld, but I could just remove a panel here and there and replace it with a new one. Simple. Even the idea of plug welding seemed easily within my grasp. Then as I got further involved, I realized it was only easy on paper. Have to admit, though, there hasn't been anything that I've had to farm out yet. Even some of the more daunting and complicated tasks were do-able if I planned it out and took my time. I actually like fabbing stuff. Really makes you feel like you're solving a puzzle.
#42 danotje21
danotje21
  • 38 posts
Posted 02 February 2013 - 11:57 PM
Look ma, no clamps!
Finally got the wings welded in place. Not a lot of photos this time as it is pretty straight forward, but I have a few.
Top in work
Set up for the underside
Underside. Of note, you can see my little magnetic flashlight here. It is actually a grill light, but it works great for welding. Can position it most anywhere and it doesn't auto darken the helmet.
And done.
Got a good look at my next bit of work while underneath. After the other side, this shouldn't be too hard.
All in all, pretty good day. Cheers!
#43 danotje21
danotje21
  • 38 posts
Posted 10 March 2013 - 01:13 PM
Small, but important update...driver's side outer sill going on! This is another one of those things that is seemingly insignificant given the amount of work required, but in looking back, it is one of the areas that needed the most attention. Good feeling to weld on solid metal. Here's a couple of pics.
Actually needed to fill in those two indentations before proceeding. Not terribly difficult, but took a little time.
Again, not really exciting, but it is progress. Since it is kind of a boring update, thought I'd give you a preview of my next project...
1958 VW ragtop...cheers!
#44 AndrewMini
AndrewMini
  • 154 posts
Posted 10 March 2013 - 05:34 PM
looks like a nice project. nice welding as well!
#45 steven
steven
  • 1,195 posts
Posted 10 March 2013 - 07:04 PM
looks great lovely work !
