Heater Removal
23 replies to this topic
#16 reallybig
reallybig
  • 613 posts
Posted 06 May 2012 - 09:21 AM
i just connected the heater pipes together in the cockpit. that way you could theoretically just reconnect the heater unit without matrix as it's an electronic fan in the unit as far as i know.
someone said something somewhere about blanking causing a heating loop...
#17 tiger99
tiger99
  • 8,584 posts
Posted 06 May 2012 - 12:06 PM
The heater pipes shold be blocked, not linked together, if you don't have a heater. Otherwise, you are allowing a fair flow of hot water to bypass the radiator.
#18 sledgehammer
sledgehammer
  • 3,108 posts
Posted 07 May 2012 - 02:13 PM
Pipes can be linked together - no need to block them
just switch the valve off - so no flow - same as a normal mini with heater off
have seen a mini somewhere with a copper pipe running below the screen ??? (not sure it worked - can't see why not)
#19 tiger99
tiger99
  • 8,584 posts
Posted 07 May 2012 - 05:44 PM
If you have a valve, yes I totally agree. For some reason I seem to recall doing it to a Mini that did not have a valve on the cylinder head, and used an inline valve, possibly because it was a Metro engine.
#20 RandyBMC
RandyBMC
  • 58 posts
Posted 23 August 2012 - 08:43 AM
I have an Spi without heat and the pipes are joined. Does the Spi have a heater valve, and if so, where is it and how is it closed? A photo would really help.
Thanks!
#21 davies88
davies88
  • 18 posts
Posted 12 June 2016 - 11:14 AM
just wondering if you remove the heater for good, what should you do with the pipework from the engine?
#22 tiger99
tiger99
  • 8,584 posts
Posted 12 June 2016 - 01:23 PM
Blank both pipes off at the engine. In most cases that needs a blanking plate and gasket on the head, and a bottom hose with no branch.
#23 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 12 June 2016 - 02:01 PM
I'd link the 2 pipes together so you get good flow round your engine with no hot spots at cylinder no 4
Edited by HUBBA.HUBBA, 12 June 2016 - 02:03 PM.
#24 tiger99
tiger99
  • 8,584 posts
Posted 12 June 2016 - 03:25 PM
It has already been pointed out that you do not link the pipes together. When the heater is turned off in hot weather there is no circulation anyway.
