Lightweight Flywheel For Daily Driver?
56 replies to this topic
#16 Tupers
Tupers
  • 4,159 posts
Posted 09 May 2012 - 06:29 PM
Something like a Swifttune Retro Road flywheel would be quite nice on a road engine. You don't really need anything lighter.
#17 racingbob
racingbob
  • 3,061 posts
Posted 09 May 2012 - 06:39 PM
have a chat with swiftune about it
what are you revving it to, its only a 276
for road car you need the low down torque
you will miss it
mine is mg metro engine, maniflow full system
mg cam ( like 266 ), KN, modified inlet ports
balanced engine, perfect for quick road
#18 adam davies
adam davies
  • 212 posts
Posted 09 May 2012 - 07:57 PM
I've emailed mini spares but I'll also ask swiftune. I rev the engine to about 4k, but quite often I do like to put it through the rev range
#19 jaydee
jaydee
  • 8,565 posts
Posted 09 May 2012 - 08:18 PM
You want to rev the engine to 4k with a 276..it will fall off cam at each gearchange.
Go for a kent 266 instead.
That swifty flywheel looks quite pricey.....
#20 adam davies
adam davies
  • 212 posts
Posted 09 May 2012 - 08:22 PM
I can't really change the cam now. I bought it as part of a kit and the cam and the valve springs are already in the block and head. My father reckons the 276 is a good cam and has used it a few times
#21 Tupers
Tupers
  • 4,159 posts
Posted 09 May 2012 - 08:28 PM
A 276 is a good cam but you'll need to change the way you drive to make the most of it.
For what it's worth changing a cam isn't that hard especially with the engine out and you should be able to get decent money for the 276 if it's in good nick.
#22 adam davies
adam davies
  • 212 posts
Posted 09 May 2012 - 08:31 PM
How do you mean change the way I drive it?
#23 james962
james962
  • 2,677 posts
Posted 09 May 2012 - 09:53 PM
By taking the engine beyond 4k. Think more along the lines of 6.5/7k
#24 adam davies
adam davies
  • 212 posts
Posted 09 May 2012 - 11:41 PM
Ah right, I get what you mean. I've read through David Vizard's book again tonight and read the section about lightened flywheels and I've decided to take a risk and get one. Would I want the lightest one available or will a "heavy" lightened flywheel do?
#25 racingbob
racingbob
  • 3,061 posts
Posted 10 May 2012 - 08:42 AM
at your own peril, have warned you about torque
whats the point unles revving the balls out of it
which your not going to, and balanced engine
#26 racingbob
racingbob
  • 3,061 posts
Posted 10 May 2012 - 08:44 AM
i personally would go for it i think it will be fine and i must hav got mixed up with another thread on here
as far as im concerned from EXPERIENCE bad advice
#27 Twisty
Twisty
  • 576 posts
Posted 10 May 2012 - 09:33 AM
i have driven a mk2 S with a modded head and a 266 cam lightened fly and it was awesome very quick smooth and very usable. i have also driven a car fitted with the 276 cam and it was hard work, very lumpy at idle and as said above had to rev it just to pull off which i felt like a bit of a boy racer and thats not good.
is there anyone you can call on with the 266 or 276 cam for you to have a drive in?
#28 adam davies
adam davies
  • 212 posts
Posted 10 May 2012 - 10:17 AM
I don 't think there is. My father's old cooper has the 276 but the engine is ot and the car has been still for a good 5 years
#29 jaydee
jaydee
  • 8,565 posts
Posted 10 May 2012 - 11:49 AM
More about 5.5k on a 3.44 diff, the engine will still be nippy, while taking the engine above 6k all the time will shorten its life a lot ;)
#30 adam davies
adam davies
  • 212 posts
Posted 10 May 2012 - 12:50 PM
To keep it on cam I'm going to have to rev it quite a bit so the flywheel should be suited for the engine shouldn't it?
