Ever Double Clutch In Your Mini ?
58 replies to this topic
#1 matthewrussell
matthewrussell
  • 378 posts
Posted 10 May 2012 - 10:52 AM
Just wondering if anyone ever double clutches ???
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2012 - 10:54 AM
As soon as i start driving mine properly i will be learning how to double de-clutch as it is better for the gearbox and when your gearbox is a 50 year old design then any help to keep it going the better ! :)
also you sound like a racing driver coming up to a roundabout and down shifting while blipping the revs in between gears :P
#3 matthewrussell
matthewrussell
  • 378 posts
Posted 10 May 2012 - 10:59 AM
Lol yeh, well I had ago the other day and I was so scared It wasn't going to go into gear for some reason but no I'm with you I like the sound and defo feels better :)
#4 Miniman1987
Miniman1987
  • 79 posts
  • Local Club: IMOG
Posted 10 May 2012 - 11:01 AM
I try it every now and again with varied results, having size 13 feet can be awkward in the confined space of the mini footwell >_<
Edited by Miniman1987, 10 May 2012 - 11:03 AM.
#5 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 10 May 2012 - 11:05 AM
Yep, with weak syncros it is a must
#6 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 10 May 2012 - 11:14 AM
I do on a few corners, as much as I can justify with a 998
#7 konyo
konyo
  • 1,107 posts
  • Local Club: Mini Freakz of Sussex
Posted 10 May 2012 - 11:17 AM
Sorry to sound like an idiot? But what is double Clutching? :S
#8 George929
George929
  • 556 posts
Posted 10 May 2012 - 11:20 AM
you dip the clutch twice. so you press it down take it out of gear then let it off then press it down again and put it into gear.
some people getting it a little mixed up with Heel & toeing above.
#9 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2012 - 11:21 AM
When going up into the gear box you go from 1st to neutral, let the clutch out, clutch in up to 2nd, for instance,
and when coming back down its the same but blipping the revs in neutral to speed the gearbox up slightly then clutch in, into desired gear.
I believe thats all of it.
EDIT: and well heel and toe'ing is part of it when coming back down the gearbox as speeding the gearbox back up when changing down gears helps the syncros dosnt it?
Edited by Alex_B, 10 May 2012 - 11:22 AM.
#10 konyo
konyo
  • 1,107 posts
Posted 10 May 2012 - 11:22 AM
Ohhh ok... Thanks, will try this out :P
#11 matthewrussell
matthewrussell
  • 378 posts
Say 3rd gear high rev put your clutch down put it in nuteral rev match so tap your acceleration few time then put clutch down into 4th, so clutch down tap acc then clutch down then back on acc :)
#12 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2012 - 11:24 AM
i didnt think you should blip the revs when going up gears just down, ?
#13 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 10 May 2012 - 11:25 AM
Mine are usualy combined with heal and toeing.
Engine blipped to match speed of drivetrain
Edited by mk3 Cooper S, 10 May 2012 - 11:26 AM.
#14 George929
George929
  • 556 posts
Posted 10 May 2012 - 11:27 AM
idealy if your a racing driver haha. you don't need the clutch. that is the best on the gear box. if you get everything right so the engine revs match the gear speed then no clutch isnt needed. i cant find the video but i remember seeing an old rally video. and he didnt use the clutch once after setting off
#15 matthewrussell
matthewrussell
  • 378 posts
Posted 10 May 2012 - 11:28 AM
Yeh so you keep the power there ???
