After a reallly naff start to the year spent mostly in hospital with peritonitus , I'm nearly well enough to get back on with the important things in life, working on my Mini!
As such I'm on the lookout for some bits, namely;
Rear seats, black (no red piping) fabric or leather, vinyl is ok
Maniflow LCB (either version).
Hif44 carb.
8 Slat grille - I'm going to be cutting some slats out so the odd ding may be ok.
Push centre piece for the Mountney steering wheel.*Potentially sorted*
**Sorted!**
ABS / Curley Mini Miglia arches.
Solid tower subframe mounts.
Solid lower subframe mounts.
**Sorted!**
A pair of Mini hub carriers (can return a set later on, it's so I can do the conversion off the car to save on down time)
Black and white hand brake gaiter.
Speedo, aftermarket ideal. Preferably modern'ish.
Evolution Tex bullet mirrors - direct replacement style (Are these the ones you can actually see sh*t out of?)
Adjustable Tie bars.
Set of hi-lo's
MPi bin covers.
I'm located in Basildon, but can meet to collect.
More to come!
Cheerios
Edited by Skortchio, 24 May 2012 - 01:45 PM.
