does anyone know how i seperate these connectors.
hose.JPG 64.61K
7 downloads
Help With Disconnection
mktillidie
, May 10 2012 03:00 PM
7 replies to this topic
Posted 10 May 2012 - 03:00 PM
Posted 10 May 2012 - 03:03 PM
Yes
Posted 10 May 2012 - 03:10 PM
care to elaborate please
Posted 10 May 2012 - 03:13 PM
Sorry was being pedantic!
They are quickfit connectors for fuel feed and return.
Push them downwards, then still holding them down push the lower centre part in/upwards and pull the whole thing up, it will then release from the metal fuel lines.
Posted 10 May 2012 - 03:15 PM
cheers will give it a go
Posted 10 May 2012 - 03:27 PM
How do you remove the break vacuum pipe?
Posted 10 May 2012 - 03:28 PM
Same technique push it down then hold the centre of the connector down as you pull the pipe up
Posted 10 May 2012 - 03:39 PM
With the fuel lines - take the fuel cap off first to release pressure, then have a similar sized breather hose to loop the system back on itself - saves a lot of fuel all over the garage floor and a fumey work environment.
