Apple Now Make Different Colour Iphones
38 replies to this topic
#16 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2012 - 08:53 PM
Unless you have a lot of patience dont touch a 3g/3gs i dont know what the 4 is like but i changed the back on my 3g when it cracked around the dock connector, took me a good few hours, very fiddly around the volume rocker and then spent 30 mins getting the screen connections in properly so that it worked perfectly, and in the end i have marked the bezel around the screen and the sim card tray isnt as flush as it used to be, im not worried as i will have to change the back again when i come to sell as its cracked again! by the way blue looks ace!
Edited by Alex_B, 10 May 2012 - 08:54 PM.
#17 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 10 May 2012 - 09:03 PM
Sounds like something went wrong for you.
Changing a back on a 3G should take under 1 minute
#18 Andrew O
Andrew O
  • 1,425 posts
Posted 10 May 2012 - 09:04 PM
It won't be an apple warranty it will be with the company it's self.
And no my warranty is now void but I have insurance which covers it
#19 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2012 - 09:07 PM
The back of a 3g holds everything its opposite to i4's on 3gs you unscrew the 2 screws at the bottom, then screen out, then logic board, battery stuck on the back, then all the buttons are mounted on the back casing, so unless you are using an ak47 then it will take longer than a minute ;)
#20 daddy2coull
daddy2coull
  • 141 posts
Posted 10 May 2012 - 09:23 PM
i might give it a go on my 4, i really wanted white, but after waiting three hours for mine only to find out they only had black, i had no choice
#21 Black.Ghost
Black.Ghost
    Formerly known as TneMini.
  • 2,567 posts
Posted 10 May 2012 - 09:26 PM
If all you want is a white one, what about advertising in various places for a swap? I'm sure there is someone out there who wants a black one not a white one?
#22 daddy2coull
daddy2coull
  • 141 posts
Posted 10 May 2012 - 09:28 PM
i could do, but i'm taking it apart anyway to fit a bigger battery
#23 daddy2coull
daddy2coull
  • 141 posts
Posted 10 May 2012 - 09:29 PM
and i'm dying to open it lol
#24 Black.Ghost
Black.Ghost
  • 2,567 posts
Posted 10 May 2012 - 09:31 PM
:lol:
#25 Andrew O
Andrew O
  • 1,425 posts
Posted 10 May 2012 - 09:37 PM
A bigger battery ? Hows that going to work. There's no space for one
#26 daddy2coull
daddy2coull
  • 141 posts
Posted 10 May 2012 - 09:38 PM
bigger capacity
#27 Andrew O
Andrew O
  • 1,425 posts
Posted 10 May 2012 - 09:46 PM
Don't be worried about changing the screen, Just label everything and do it in steps
#28 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2012 - 09:49 PM
Who was worried about the screen?
#29 james962
james962
  • 2,677 posts
Posted 10 May 2012 - 10:15 PM
Looks good. I daren't do anything like that to mine, I'll loose something. And I really cannot do fiddly jewellers screwdrivers etc; i'll stick to the 1/2" AF spanner ;D :D
Edited by james962, 10 May 2012 - 10:16 PM.
#30 sebseb8
sebseb8
  • 92 posts
Posted 11 May 2012 - 10:23 AM
iPhone 3g/S are not worth muckin around with unless your just changing a screen. I tried to re-build one a friend smashed up and it was stupidly complicated.
iPhone 4/S is very easy to work on if you take the time and lay out parts in the correct order you take it apart in. Instructions are avaliable at ifixit.com and they are very good if anyone fancies having a go
