Mini Sidewalk 1.3 Si (Micra Build)
#16
Posted 20 May 2012 - 07:11 PM
#17
Posted 20 May 2012 - 07:21 PM
Jordie, I may be able to make one at a later time when I do another, but would be subject to a exchange on a front subby.
#18
Posted 20 May 2012 - 07:24 PM
what's the thread size?These are the ones I used, I'll try them, but allow enough room around them for the larger one's should I need them.
#19
Posted 20 May 2012 - 07:28 PM
#20
Posted 20 May 2012 - 07:32 PM
#21
Posted 20 May 2012 - 07:38 PM
#22
Posted 20 May 2012 - 07:43 PM
mine are nearer 40-45 degrees. 35 degrees isnt far from that, i'm a great believer in if it looks right it is right, go for it...I was thinking that today myself, now I can see it in front of me it will be important to get the position right. i was thinking 35 degrees would be a good position to allow the engine to bear down on the mounts, but also damping front to rear movement.
#23
Posted 23 May 2012 - 08:21 PM
The frame was a snug fit, and only needed to make a small modification to the body work to make it fit, just cut 2 triangles off the front panel mounting brackets.
some pics.
2012-05-23_14-40-03_733.jpg 64.75K 62 downloads 2012-05-23_14-40-08_111.jpg 50.71K 51 downloads
2012-05-23_14-40-13_274.jpg 62.71K 36 downloads 2012-05-23_14-40-19_913.jpg 70.98K 55 downloads
managed to get one mount fabricated
2012-05-23_17-48-07_273.jpg 50.72K 41 downloads
And how the engine sit's in the car
2012-05-23_17-48-49_687.jpg 51.5K 64 downloads
@Rids, what thickness plate did you use for you engine mounts, and if fact what wall thickness tube did you use, I feel I'm over engineering it a little
#24
Posted 24 May 2012 - 05:04 AM
#25
Posted 24 May 2012 - 05:15 AM
But yea reading all the threads really helped me, the coversion isn't too bad, but made so much easier in the fact you can see how other people have over come hurdles.
#26
Posted 24 May 2012 - 01:50 PM
#27
Posted 24 May 2012 - 05:23 PM
I used 6mm for my engine mounts and strengthened them by welding in webs where i could, giving a strong triangular shape. the box section i used was 1 inch, it looks smaller than what you are using. I think the wall thickness of the box section was about 2-3mm, it seems strong enough, it's on it's second summer now with no problems. yours looks neat and strong,
Edited by rids, 24 May 2012 - 05:27 PM.
#28
Posted 24 May 2012 - 05:46 PM
Now it's been trial fitted and once the mounts are finished, i'll be adding a little more strenghtening, I didn't realise tho how thin the Metal was on the original subframe.
I've got use of a lathe now so will hopefully be able to do my drive shaftes and turn down the camshaft pully, Just need to convert it from 3 phase to single phase
#29
Posted 24 May 2012 - 05:50 PM
#30
Posted 24 May 2012 - 05:59 PM
Also I think i've decided to go for a custom inlet, at least that way I can switch the engine into other cars with mods should I need too
