Factors Affecting Fuel Consumption
25 replies to this topic
#1 jakejakejake1
jakejakejake1
  • 644 posts
Posted 15 May 2012 - 12:02 PM
Hi everyone,
I'm sure there is a problem with my car, but unsure what it is.
The car is a 1991, 998, with freeflow manifold, alloy inlet manifold and 12g295 head. Standard cam.
My MPG have been decreasing quite rapidly the last few times I have filled up.
I have made a spreadsheet and calculated my MPG by always filling the tank and noting down the mileage on the car, so no estimating from the gauge.
Now when i tried this 6 months ago i was getting between 35-50 mpg depending on where i drove etc etc.
But the last four mpg calculations have been 39, 30, 26, 23.
Now clearly something has happened and even when I used to floor it everywhere i couldn't get it below about 30mpg, now its dropped to 23 and I'm driving very carefully. And the 39 and 30 values were obtained over long distance at about 50-60 mph.
Admittedly the journeys haven't been the longest (5-8miles on average), but then again, they never have been.
What could be causing this huge fuel consumption/ loss of fuel?
Thanks, Jake
#2 BobJob
BobJob
  • 88 posts
  • Local Club: Looking for one...
Posted 15 May 2012 - 12:31 PM
Have you put on lots of weight recently? :P
#3 Ryang556
Ryang556
  • 2,747 posts
  • Local Club: Top Mini
Posted 15 May 2012 - 12:44 PM
Checked the fuel hose going into the carb etc? :D
#4 nafnaforiginal12
nafnaforiginal12
  • 282 posts
  • Local Club: Cumbria Mini Cruisers
Posted 15 May 2012 - 12:46 PM
Time for a service?
Just a thought ;D
#5 jaydee
jaydee
  • 8,565 posts
Posted 15 May 2012 - 01:04 PM
Clogged air filter or poor fuel quality?
Traffic? Carrying extra weight?
#6 Wil_h
Wil_h
  • 3,244 posts
Posted 15 May 2012 - 01:05 PM
First thing I'd do is clean the carb and check the dashpot oil. then check that there are no air leaks on the carb (after the throttle plate). Check that the vac advance is working, this is key to good mpg.
Other things that will affect mpg, binding brakes (the rears are great for getting stuck). flat tyres, although when you do the maths, they have to be really flat to make any differance.
Check also that your exhaust is in good order, a collapsed scilencer will be a problem. And finally renew your airfilter if it's dirty.
As suggested above a service of plugs, leads, dizzy bits etc. will be worth while.
#7 Ethel
  • 26,586 posts
Posted 15 May 2012 - 01:13 PM
Look at the plug colour to see if it's a fuel issue.
#8 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 15 May 2012 - 03:12 PM
Roofrack?
Binding brake?
#9 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 15 May 2012 - 03:19 PM
is the head leaded or unleaded?
#10 Tommyboy12
Tommyboy12
  • 2,255 posts
Posted 15 May 2012 - 04:58 PM
Good shout on the leaded head. 12G295 will be leaded as standard. That lead build up may be wearing away.
#11 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 15 May 2012 - 05:13 PM
Easily checked with a compression test
#12 brad-the-bear
brad-the-bear
  • 1,114 posts
:proud: :genius:
#13 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 15 May 2012 - 05:15 PM
hgf?
#14 maggies_minder
maggies_minder
    TMFs New official Spamster
  • 4,393 posts
Posted 15 May 2012 - 05:29 PM
fat passengers
#15 Cooperman
  • 23,513 posts
Posted 15 May 2012 - 11:00 PM
The way to improve the mpg, assuming the engine is set-up properly, is to do the following:
Fit narrow wheels and 145-section tyres, remove the wheel arch extensions, remove the big wing mirrors and replace with the small rectangular mirror only on the driver's side A-post near the top, drive with the windows closed, drive with the tank no more than 1/2 full, don't have a roof rack, drive in high gears without using full throttle, don't carry unnecessary weight around and don't have fat passengers.
