Factors Affecting Fuel Consumption
#16
Posted 15 May 2012 - 11:49 PM
*this could be dangerous if you carry attractive passengers. A nice pair of jugs might become very distractive.
#17
Posted 16 May 2012 - 07:14 AM
The way to improve the mpg, assuming the engine is set-up properly, is to do the following:
Fit narrow wheels and 145-section tyres, remove the wheel arch extensions, remove the big wing mirrors and replace with the small rectangular mirror only on the driver's side A-post near the top, drive with the windows closed, drive with the tank no more than 1/2 full, don't have a roof rack, drive in high gears without using full throttle, don't carry unnecessary weight around and don't have fat passengers.
I would say this is great advice if you do a lot of higher speed driving, where aerodynamics play a major role, but it won't make up the loss of mpg that the OP is asking about as non of these parameters have changed.
#18
Posted 16 May 2012 - 09:49 AM
The airfilter is a K&N replacement type, which is fairly new and not clogged, this and the spark plugs, rotor arm, dizzy cap and HT leads were replaced around 6 months ago, when i first started noting my MPG, and i wouldn't have thought any of these would deteriorate that severely in that time space, they all look in good condition.
The tyres were a little low on air (about 20-25 psi), but as said i cant image that making such a huge difference.
The spark plugs are a little on the black side, but I wouldn't say they were overly rich.
I have attached a small bottle to the carb overflow to see if I'm losing any fuel out of that, and the same for the tank breather, and I'm going to keep an eye out for a leaking petrol cap.
Does anyone know the difference the ignition timing would make to fuel consumption?
Thanks for all the input
#19
Posted 16 May 2012 - 10:16 AM
They make a HUGE difference, set them at 30 psi.
#20
Posted 16 May 2012 - 10:22 AM
Compressions must also be right too. A badly seated or slightly burned valve will screw up consumption.
#21
Posted 16 May 2012 - 11:33 AM
It won't be huge, but it will have an effect.
The timing will make a significant differance on cruise if your vac advance is not working, but not much differance in town. If the dizzy hasn't moved then the timing should be the same anyway (ignoring wear).
Plugs being black does indicate a rich mixture. what carb do you have? If it's a HIF there might be a problem with the choke seals. actually, whatever carb you have, check that the choke is properly closing.
#22
Posted 16 May 2012 - 01:08 PM
I will check the choke as well.
I also found the vac-advance pipe (where the smaller one fits inside of the larger rubber one) was leaking slightly, causing the vac-advance to not hold vacuum very well.
Sorted this by putting a smear of grease around the inner pipe before inserting it.
This could of made a difference as most of my driving is part throttle.
#23
Posted 20 May 2012 - 08:23 PM
Just filled up and calculated I was getting 23 MPG again.
I have no idea what is causing this low fuel efficiency, but i'm sure that something is amiss.
I checked the mixture again with the Colourtune and at idle it is fine, I lowered the idle speed as well to see if this had any effect.
Is there anyone in Bath (or close) who could help me do a compression test as I don't have the equipment :)
Posted 11 July 2012 - 01:29 PM
#25
Posted 11 July 2012 - 01:46 PM
http://www.secondcha.../public/186.cfm
#26
Posted 11 July 2012 - 02:10 PM
Jake
