Can any one offer any advice as to what is needed for the removal and refitting?
Head being removed to get skimmed due to engine over heating.
Many thanks to one and all.............
Posted 17 May 2012 - 02:00 PM
Posted 17 May 2012 - 03:58 PM
Posted 17 May 2012 - 06:53 PM
Posted 17 May 2012 - 07:03 PM
Posted 18 May 2012 - 09:26 AM
Posted 18 May 2012 - 09:31 AM
Posted 18 May 2012 - 01:17 PM
Posted 18 May 2012 - 01:21 PM
Posted 20 May 2012 - 09:43 PM
Posted 19 September 2012 - 12:13 PM
I recommend getting a specific non-marring stud removal tool (5/16" I believe is what is needed for the A-Series head studs. I can check this later if there's any question here.) These tools look like a socket, with an internal rotating clamp to apply pressure when turned.
Edited by toplessmini, 19 September 2012 - 12:16 PM.
Posted 19 September 2012 - 05:58 PM
The head is supposed to come of without having to remove the studs. However the head is often so accutomed to sit on the block, that it can be hard to remove as you have experienced. I don't have much advise on how to overcome this problem except I know one is supposed to resist the temptation to use a screwdriver or similar to pry them apart because the head is easily chiped. Mine came of when I used the inlet and outlet port on one side as a holding grip.So I've finaly got around to remal of my head........................
Only to find it well and truly stuck, I've managed to remove some of the head bolts but need to get hold of one of those stud removal tools.
Any one know what there call, size and where to get one?
Posted 20 September 2012 - 10:08 AM
Posted 20 September 2012 - 08:13 PM
Posted 24 September 2012 - 07:36 PM
Posted 26 September 2012 - 11:10 AM
